1380 Cc Engine Problem
Posted 24 April 2019 - 02:45 PM
Firstly when I change quickly gear from 3 to 4 the engine increase rates without gain speed !
Secondly, I think I have problem with the distributor because sometimes lose power and If turn it right or left the problem being solved !
Thank you
Posted 24 April 2019 - 03:08 PM
clutch slipping.
poor wiring.
Posted 24 April 2019 - 06:39 PM
clutch slipping.
poor wiring.
How can I diagnose clutch slipping?
Do you think that If I change speedo cable , will solve my problem??
Posted 24 April 2019 - 06:59 PM
clutch slipping.
poor wiring.
drive, switch to 4th gear and stamp on the throttle. if the revs go up and the speed doesnt really change, youre slipping.
Posted 24 April 2019 - 07:03 PM
which sounds just like the problem that has been described.drive, switch to 4th gear and stamp on the throttle. if the revs go up and the speed doesnt really change, youre slipping.
clutch slipping.
poor wiring.
Posted 24 April 2019 - 07:12 PM
which sounds just like the problem that has been described.drive, switch to 4th gear and stamp on the throttle. if the revs go up and the speed doesnt really change, youre slipping.clutch slipping.
poor wiring.
So that's my problem!
I bought an ultralight flywheel and a CLUTCH PLATE 5 FINGER , without change diaphragm!
What do you think ??
clutch slipping.
poor wiring.
which is why i told him to do it again ![]()
