Which Electronic Ignition Kit?
7 replies to this topic
#1 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 25 April 2019 - 10:39 AM
Hi Everyone.
I hope someone can give me some advice.
I don't have very much to do with the mechanical side of things on the Mini's when it comes to upgrades and conversions etc.
I have a 1989 Mini 30 here with the standard 998cc engine. The distributor is fitted with standard points and condenser and we would like to change this to an electronic ignition.
I have seen complete distributors with the electronic kit in and have seen Igniter packs etc but I am not too sure what I need for this car.
Would someone mind pointing me in the right direction of a simple conversion kit that just fits into the standard Lucas distributor in place of the points. Or if needs be, a replacement electronic ignition distributor.
Many thanks
Ben
#2 Steve8274
Steve8274
  • 580 posts
Posted 25 April 2019 - 11:33 AM
I have recently installed some on my 998.
All seems good and no problems fitting.
They are from powerspark
https://simonbbc.com...9d-distributor/
#3 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 25 April 2019 - 12:03 PM
Thanks for that. Looks exactly what I am looking for
#4 jime17
jime17
  • 948 posts
  • Local Club: None
Posted 25 April 2019 - 12:30 PM
I've used exactly that. It's been great. Fit and forget.
I did however buy a distributor base plate for a 45d and swapped it into my 59d.
They are identical I believe except for a locating pin in the 59d one that locates the points.
This pin would obstruct fitting of the powerspark module.
You can cut it off but I chose to change the plate in case I ever wanted to revert back to points. (I can't see me changing now but you could keep the old plate with points mounted in the car in case the module ever fails)
#5 cal844
cal844
  • 9,671 posts
  • Local Club: TFMOC
Posted 25 April 2019 - 01:13 PM
I've fitted a 65D type dizzy to my 998 mini, it runs well. You'll need to get the vacuum advance unit changed to suit the 998 As the 65D comes from the 1275 cars.
#6 cooperd70
cooperd70
  • 737 posts
Posted 25 April 2019 - 01:51 PM
Ben_O I've got a 1990 998 and have fitted the accuspark conversion, cheap as chips for 35 notes. Has run perfect since fitting. Check out their website.
Edited by cooperd70, 25 April 2019 - 01:52 PM.
#7 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 25 April 2019 - 02:18 PM
Thanks everyone.
That cleared things up nicely.
Ben
#8 TheFabMini
TheFabMini
  • 459 posts
Posted 25 April 2019 - 07:06 PM
+1 for accuspark kit from eBay
Fitted it last year, had to redo ignition timing
But haven’t looked at it since because it’s just worked perfectly
