Cv Circlip Pliers And Clips
19 replies to this topic
#1 beardylondon
beardylondon
  • 1,561 posts
Posted 25 April 2019 - 11:03 AM
I am going to fit the proper circlips to the CV boots, as the cable ties I used seems to be allowing grease to leak out.
So I wondered if any one had any recommends on decent quality clips and good pliers?
These look pretty good:
https://www.amazon.c...s/dp/B0012M7RE2
#2 nicklouse
  • 18,606 posts
Posted 25 April 2019 - 11:05 AM
nothing to do with Circlips.
but yes those type work well with the metal boot straps.
I have these https://www.amazon.c...9H3WKGXERT4W4X3
Edited by nicklouse, 25 April 2019 - 11:06 AM.
#3 cal844
cal844
  • 9,624 posts
  • Local Club: TFMOC
Posted 25 April 2019 - 01:09 PM
I use good quality cable ties done up tight
#4 imack
imack
  • 2,128 posts
Posted 25 April 2019 - 01:27 PM
I use these
#5 beardylondon
beardylondon
  • 1,561 posts
Posted 25 April 2019 - 03:49 PM
thanks Nick, I thought they were called CV Circlips for some reason!  So I'll get a pair of the ones you suggested. cheers.
#6 beardylondon
beardylondon
  • 1,561 posts
Posted 25 April 2019 - 03:51 PM
Yes me too ever since I can remember, until I discovered this yesterday...
Hence wanting to fit the proper metal boot straps
#7 beardylondon
beardylondon
  • 1,561 posts
Posted 25 April 2019 - 03:58 PM
thanks, this looks like it might get them on tighter?
I use these
#8 imack
imack
  • 2,128 posts
Posted 25 April 2019 - 05:38 PM
I use these
I've had issues with the type of clip that uses the type of tool Nick is suggesting. I've found the crimped part of the clip can be quite tall and foul the inside of the hub carrier and knock the clip and cv boot off, same issues sometimes with cable ties in my experience.
#9 monkey
monkey
  • 1,382 posts
  • Local Club: Diss Mini Club
Posted 25 April 2019 - 05:59 PM
I have a cheap all plastic tool similar to this:
417513 All Steel Heavy Duty Cable Tie Gun Tensioner Tightening Professional Tool https://www.amazon.c...i_VuFWCbXE4SBVS
My cheapo plastic one gets zip ties really tight
#10 imack
imack
  • 2,128 posts
Posted 25 April 2019 - 06:34 PM
I use these
It does pull the clips up nice and tight. The clamp part of clip is a nice low profile too.
#11 GraemeC
GraemeC
  • 7,438 posts
Posted 25 April 2019 - 06:59 PM
Where do you buy the straps themselves from imack?
I have the pliers but have never found a decent source for the straps.
#12 imack
imack
  • 2,128 posts
Posted 25 April 2019 - 08:30 PM
I bought mine from eBay, can't remember the seller I bought them from but if you search cv boot clip clamp you should find them amongst the more common crimp up type.
Here's one I just looked up.
Update: search cv boot strap fastener - far more options.
Edited by imack, 25 April 2019 - 08:34 PM.
#13 beardylondon
beardylondon
  • 1,561 posts
Posted 25 April 2019 - 08:39 PM
Thanks all, I'm going to order that tool and some of those straps from PAS.
#14 Ethel
  • 25,971 posts
Posted 25 April 2019 - 09:31 PM
About 10BC (yes, Before Cable ties) we used galvanised fencing wire. You could get a really snug fit by twisting the ends together with pliers. Fold the end with the usual shaft rotation so if it pokes up it will get knocked back against the joint.
#15 GraemeC
GraemeC
  • 7,438 posts
Posted 26 April 2019 - 05:05 AM
Perfect - places now do them in decent quantities, last time I looked you could only get them in pairs, so to buy 10 sets was quite expensive.
