Cam Followers
25 replies to this topic
#1 whistler
whistler
  • 1,818 posts
Posted 28 April 2019 - 12:40 PM
Fitted a minispares evo001 cam and followers into the wife's 1330 about 1000 miles ago. Changing the gearbox so checked out the cam etc. Three of the followers are not rotating. Is this going to be a problem in the future?
Edited by whistler, 28 April 2019 - 12:40 PM.
#2 ACDodd
ACDodd
  • Mini Docs
  • 2,767 posts
Posted 28 April 2019 - 01:00 PM
While they are out send them to Keith Calver to have them refaced with the proper radius.
Ac
#3 mini13
mini13
  • 3,811 posts
Posted 28 April 2019 - 06:18 PM
Also check the lifter bores for marks and that they rotate ok with a little light oil on them, sometimes they need a good clean, or even a very brief swipe with a brake hone if there's any marks
#4 Spider
  • 15,141 posts
Posted 28 April 2019 - 06:50 PM
The Isky and ARP Followers are good. Made from the right material and have decent heat treatment, sensibly priced.
#5 Rorf
Rorf
  • 866 posts
Posted 28 April 2019 - 08:07 PM
These cheap Mini Spares cam followers appear to have no radius whats so ever - I am starting to get quite peed off with some of the Mini Spares parts, not good quality at all :goaway:
#6 unburntfuelinthemorning
  • 1,990 posts
Posted 28 April 2019 - 09:29 PM
Where does one purchase Isky or ARP followers?
#7 Spider
  • 15,141 posts
Posted 29 April 2019 - 03:57 AM
USA.
https://www.iskycams.com/shop/  - though Mini Spares do / did have them
https://www.aptfast.com/  (sorry, I seem to have ARP on the brain - it's APT - David Vizard was founding partner in the business and had a hand in it for a very long time)
#8 Rorf
Rorf
  • 866 posts
Posted 29 April 2019 - 05:46 AM
That cam lobe in your photo looks to be warn too
#9 unburntfuelinthemorning
  • 1,990 posts
Posted 29 April 2019 - 07:08 AM
USA.
Are these the only ones worth buying now for any application?
#10 whistler
whistler
  • 1,818 posts
Posted 29 April 2019 - 07:56 AM
Less than 1000 miles. Fitted new with the new followers and assembly lube.
#11 Spider
  • 15,141 posts
Posted 29 April 2019 - 08:15 AM
Actually, it appears to me that the lobe has no taper ground on it and that would be why the followers aren't spinning.
#12 whistler
whistler
  • 1,818 posts
Posted 29 April 2019 - 08:50 AM
Bought brand new from Minispares (EVO001)
Edited by whistler, 29 April 2019 - 08:52 AM.
#13 johnv
johnv
  • 498 posts
  • Local Club: FDMC
Posted 29 April 2019 - 09:33 AM
excuse my ignorance, but how do you know that they aren't rotating? where should the 'taper' be? thanks
#14 Dusky
Dusky
  • 5,322 posts
Posted 29 April 2019 - 01:13 PM
Wonder of it wore the cam too..
#15 mini13
mini13
  • 3,811 posts
Posted 29 April 2019 - 01:29 PM
from the silver swipe across the  two rh followers, and the grey outer patches at the edges,
cam lobes should ( in the A series) be ground at a slight angle ( sort of cone shaped) so one side presses against the outer side of the follower causing it to rotate as the cam turns. the followers should also be slighly domed so you get more contact between the follower and lobe, from memory I think the dome/radius of the followers should be 42".  the reason all thios is don is so that everything ios constanly movwing in relation to each other so you get no spot friction points and wear is even across the areas that contact ( not that they should contact cause they should be on an oil film)
