How Do You Bleed A Clutch
3 replies to this topic
#1 wingnut
wingnut
  • 464 posts
Posted 12 May 2019 - 03:00 PM
Hi,can anyone tell me how to bleed the clutch
#2 RedRuby
RedRuby
  • 1,201 posts
  • Local Club: No
Posted 12 May 2019 - 03:26 PM
Same principle as for bleeding the brakes. Attach a tube to the bleed nipple on the clutch slave cylinder, loosen the bleed nipple and pump the clutch pedal until it runs clear of air bubbles, remembering to keep the clutch master cylinder topped up.
#3 ukcooper
ukcooper
  • 1,625 posts
Posted 12 May 2019 - 04:10 PM
so two people needed one to pump the clutch one to loosen - tighten the nipple ,end with pushing on a sown stroke to make sure the air is locked out then tighten ones nipple..
#4 cal844
cal844
  • 9,646 posts
  • Local Club: TFMOC
Posted 12 May 2019 - 09:42 PM
Yes, or a vacuum/ pressure bleeder
Edited by cal844, 12 May 2019 - 09:43 PM.
