Running On Two Cylinders
4 replies to this topic
#1 maccers
maccers
  • 1,875 posts
  • Local Club: LSMOC
Posted 13 May 2019 - 08:47 PM
Have a custom fuel injection based engine, uses coil pack wasted spark system, started car for first time in a few months, sounded a bit rough, pulled off leads one by one. Middle two firing, the ones at either end (assume 1 and 4) when pulled make no difference, any of the middle two when pulled off engine stalls.
Plugs are very recent, have had car running on them. Unlikely two leads would fail. Do coil packs fail? What’s the best way to test this? It’s running emerald ecu.
#2 cal844
cal844
  • 9,651 posts
  • Local Club: TFMOC
Posted 13 May 2019 - 09:56 PM
I'd say the leads are shot,
Swap the leads about, see if it still runs rubbish it needs leads.
#3 sledgehammer
sledgehammer
  • 3,109 posts
Posted 13 May 2019 - 10:19 PM
IIRC the wasted spark is 1 & 4 , and 2 & 3 each sharing a coil
it's a possibility the coil pack is failing
but as above - go with the cheaper things first
I also recall talk of a cheaper coil pack doing the same job ?
can't remember what car ?
Edited by sledgehammer, 13 May 2019 - 10:57 PM.
#4 maccers
maccers
  • 1,875 posts
  • Local Club: LSMOC
Posted 14 May 2019 - 04:36 AM
Cheers for that, I do have a spare set of leads. Do they break down through lack of use?
#5 maccers
maccers
  • 1,875 posts
  • Local Club: LSMOC
Posted 14 May 2019 - 12:47 PM
Changed the leads, no difference, took the plugs out and gave them a good clean up. Looks like its the coil pack, the cylinders not firing are 1 and 4, that seem to be plugged into one bank on the coils. So hopefully its that and I can get a replacement part.
