List Of Spanners And Sockets To Buy
19 replies to this topic
#1 BaronVonchesto
BaronVonchesto
  • 515 posts
Posted 18 May 2019 - 10:07 AM
While i'm in the UK, I'd like to make a trip to Halfords to buy all the SAE sockets and spanners needed to work on the mini as they're hard to come by in Malaysia. Does anyone have a full list of the sizes needed?
#2 Spider
  • 15,176 posts
Posted 18 May 2019 - 10:26 AM
I'd suggest in terms of sockets, getting a 3/8" Drive set. That will cover 99% of the entire car (for sockets).
Other Sockets you'll want are 1-5/16 and 1-1/2" (this one in a deep dish type). These will most likely be a 3/4" Drive (and that's what I'd recommend). A sliding handle T bar is a fairly useful and cheap way to drive these bigger sockets.
Spanner wise - you can often pick up good quality yet inexpensive sets in a pouch. They'll likely be open ended / ring types. Find a set that goes from 1/4" to 1" and grab 2 of those.
If the money will stretch, I'd also suggest 3 ratchet ring spanners in 7/16", 1/2" and 9/16" Get best quality in these, as poor quality ones will leave you with skinned knuckles. You could get a set, but I doubt you'd use any others than these 3 from it.
A 7/16" Line Spanner for doing the Brake lines and if your Mini has Tandem Brakes, get a 10 mm one too. You'll also want a 15 mm open ended spanner (but you can get that locally) for the flexy Brake Hoses.
That's all that springs to my mind.
#3 DeadSquare
DeadSquare
  • 3,201 posts
Posted 18 May 2019 - 10:28 AM
It depends what sort of Mini you have, but for one with imperial fastenings, the smallest is 1/4", for adjusting the brakes, and the largest is 1 1/2 " for the flywheel.
Some people buy an engraver, and engrave their name and address on their tools.  I do that, but prefix it with "Stolen from".
In view of the three recent Mini thefts, that is what I am going to engrave on every item that I can get to on my cars.
#4 mini_in_progress
mini_in_progress
  • 641 posts
Posted 18 May 2019 - 11:09 AM
I wouldnt do that, maybe my name but the address indicates where to get more tools from.....
#5 A-Cell
A-Cell
  • 1,610 posts
Posted 18 May 2019 - 11:48 AM
I reckon MokeSpider has covered it all.
I would recommend a 1/4inch drive set of sockets inch sizes and metric. Best thing I found to get to difficult to reach fixings.
Like this https://www.halfords...-socket-set-1-4
Also 1/4 to 3/8 adaptor, 3/8 to 1/2 adaptor
Good luck
#6 KTS
KTS
  • 2,465 posts
Posted 18 May 2019 - 12:43 PM
if you can get hold of them i'd recommend a metrinch spanner and 3/8" socket set - had mine for 30 odd years now and wouldn't be without them
#7 nicklouse
  • 18,711 posts
Posted 18 May 2019 - 03:09 PM
Are Harley Davison bikes sold in Malaysia? They should have most of the tools you need.
But as Spider says get a 3/8 drive set.
#8 ukcooper
ukcooper
  • 1,625 posts
Posted 18 May 2019 - 04:06 PM
nicked iff here some where
f you have any suggestions yourself, or anything I've missed please add them to this thread.
General tools
Decent set of imperial (that's inch) (metric spanners/sockets and a set for later cars )
A second 1/2" and 7/16" spanner 13mm and 11mm
1/4 drive imperial+metric socket sets
Torque Wrench1/2 + 3/8
Posidriv & Philips screwdrivers
Tap & die set (imperial)+metric
A magnetic tray to save you losing all those nuts and bolts
Coffee/sweet/jam jar of choice for storing nuts and bolts
A BIG hammer, or BFH, for those "rhubarb" moments
Rivet gun and rivets for those arches
Pliers
Molegrips
Wire brush(electric and hand)
Crowbar
Long needle nose pliers
Rubber mallet
Circlip Pliers
Roll Pin Punch
Center Punch
Brass Drift
Easy out
Hacksaw (junior and senior)
Brakes Specific
5/16" Brake adjusting spanner
Brake Pipe Spanner (7/16th's)
Eezebleed brake bleeding kit
One of those things for fitting circlips on rear brake cylinders
(http://www.minispare....aspx?pid=37917)or some pipe pliers will work.
Engine Specific
Spark plug socket
Timing gun
Compression tester
Points File (anyone remember/got these)
Valve spring compressor
Piston ring compressor
6 & 7mm hex drive = 1/4 sockets and long extensions for jubilee clips.
Oil filter wrench
Feeler gauges
Dwell meter (multimeter may or may not include dwell)
Impact driver for door striker plates and such.
Flywheel locking tool (aka an old main bearing shell)see mini spares
Flywheel puller and old drive shaft (use the drive shaft to "ring" off the flywheel, just smack it with a hammer)see guess works heavy duty
Suspension Specific
1 5/16" Impact socket for Hub centre nut, disc braked minis. Also fits steering wheel retaining nut
1 1/2" deep socket for Swivel pin cups, all minis
Grease gun
BIG breaker bar for disc hub nuts
Cone compressor tool
Hub puller
Scissor type ball joint splitter
Electrical Specific
Multimeter
Test lamp
Quality electrical crimping tool
Assorted crimps
Quality wire cutters
Wire strippers if you feel the need
Other Usefuls
Copper Grease (not technically a tool but, required)
Sand Paper/ Wet & Dry Paper
Masking tape
Labelling kit (so you remember where it all goes) post its, masking tape, bags, cardboard with holes
Blowtorch
Bottle of rust converter
A LARGE can of penetration oil (wd40 is ok, but plus gas kicks ass)
A roll of Gaffer Tape
Oil drain tray (an oil can with side cut out just doesn't cut it!)
A magnet on a bendy rod for retrieving dropped bolts
A third hand for all those jobs where two isn't enough
A nice cup of tea and a sit down
Torch (with a magnetic holder if possible)
#9 ukcooper
ukcooper
  • 1,625 posts
Posted 18 May 2019 - 04:10 PM
1"1/2 Deep= Ball joints / Gearbox internal / Flywheel
15/16" or 24mm = Sump plug
1"1/8 = Gearbox internal / Drum Brake Hub Nut / Crank Pulley Bolt
1"3/16 = Verto nut
1"5/16 = Hub nut / Tower Bolts / S-Wheel Boss /Fits crank pulley bolt / camshaft nut / post-76 front subframe tower bolt
11/16" = wheel nut's
1" = oil releaf nut
#10 ukcooper
ukcooper
  • 1,625 posts
Posted 18 May 2019 - 04:14 PM
http://www.minispare...Tools.aspx?0108
special tools or what you can get these days oil seal tool highly recommended   http://www.minispare...px|Back to shop
Edited by ukcooper, 18 May 2019 - 04:15 PM.
#11 ukcooper
ukcooper
  • 1,625 posts
Posted 18 May 2019 - 04:17 PM
find some of these for prezzys home for the lads  ebay ect ……….     http://www.minispare...px|Back to shop
#12 Spider
  • 15,176 posts
Posted 18 May 2019 - 07:50 PM
A quick google, in Malaysia and I was able to find these;-
https://www.techno.c...ducts_id=21392  (nice set!)
https://www.techno.c...roducts_id=6480
I'm sure they are quite widely available, just perhaps not in the local hardware.
#13 Mini Manannán
Mini Manannán
  • 2,860 posts
  • Local Club: man Estate
Posted 19 May 2019 - 10:14 PM
Dang you Chris, you've just cost me  £50-odd on 3 Wera spanners. I really like Wera kit  :proud:
#14 nicklouse
  • 18,711 posts
Posted 20 May 2019 - 07:14 AM
quite common out here but no AF easy to find.
#15 gazza82
gazza82
  • 3,021 posts
  • Local Club: TMF+
Posted 20 May 2019 - 07:39 AM
Wera Joker range ... not cheap though
