Clutch Housing
Posted 22 May 2019 - 06:55 PM
Posted 22 May 2019 - 07:02 PM
It is fine for racing as race tracks are fairly clean areas. Not so good for rallying or even road use, but then you wouldn't do this for a road or rally car because the ultimate weight saving is not so critical.
Posted 22 May 2019 - 07:21 PM
Holes in the wok can be weight saving, but also helps remove the heat from heavier clutches.
Posted 22 May 2019 - 07:36 PM
Posted 22 May 2019 - 07:45 PM
Surely there's a risk of grit getting in and causing damage or atleast accelerated wear?
There's always a risk with opening it up. It's whether or not that risk is tolerable and as low as reasonably practicle. I haven't put holes in my cover as the RTS clutch is apparently very good at distributing heat and my charge cooler pipes cover up the hole that is perpendicular to airflow, so I feel i've managed that risk.
Posted 22 May 2019 - 07:51 PM
Posted 22 May 2019 - 07:55 PM
Probably like a lot of mods, maybe they look cool* but is it needed/worth it/an improvement.........
(*That is usually down to personal opinion)
Posted 23 May 2019 - 04:42 AM
While it reduces weight a little, it's done for cooling of the Flywheel and Clutch.
