hi got a 1998 cooper , radiator fan keeps kicking in , temp not really going up, any ideas.its had samo hoses added by previous owner .
One thing , expansion tank lid is crap , screws up then it will slacken on the thread , is this common ?
Posted 31 May 2019 - 04:46 PM
Posted 31 May 2019 - 04:54 PM
Posted 31 May 2019 - 05:39 PM
Posted 31 May 2019 - 06:10 PM
Posted 31 May 2019 - 06:22 PM
Posted 31 May 2019 - 06:31 PM
Posted 31 May 2019 - 06:59 PM
Posted 31 May 2019 - 07:03 PM
Temp gauge yes , obviously got high wen top got loose .
Posted 31 May 2019 - 07:05 PM
Posted 31 May 2019 - 10:38 PM
many thanks everyone ..... still learning mini stuff !!!
Posted 01 June 2019 - 06:22 AM
It will start with an intermittent fault, as the connection breaks down, causing the fan to come on for no reason, a bump in road or moving by hand can make the connection again.Also, https://minispares.c.../YMQ105690.aspx
http://www.tmsmini.c...pdf/x8479bu.pdf
But these are for fans continuously running
Edited by Fast Ivan, 01 June 2019 - 06:23 AM.
Posted 02 June 2019 - 11:33 AM
back again , whats the sensor on the viper hose housing ?
Posted 02 June 2019 - 02:06 PM
I assume its the coolant temp sender, but it should be there, someones been playing.....
It should be in the thermostat housing
Edited by Fast Ivan, 02 June 2019 - 02:08 PM.
Posted 03 June 2019 - 11:51 AM
The previous owner added an additional water temperature sensor ,but the question is what for?
Two choices are to operate a temperature gauge or control a cooling fan both of which are controlled by the ECU originally.
Looking at the direction the wiring is going I would think they may have altered the wiring to the fan or would there be a second fan fitted to the rad?
