Raptor
3 replies to this topic
#1 projectjordan
projectjordan
  • 88 posts
  • Local Club: southwalesminis
Posted 03 June 2019 - 10:17 AM
Hi all
I'm currently helping a friend with a restoration, and we are looking to use Raptor on the underside, and possibly the inner floors as well.
The bare metal has been etch primered, but do we need to use a 2k primer between this and the Raptor?
cheers
Ryan
#2 cookie4343
cookie4343
    **Caution: Do Not Feed Alcohol**
  • 2,257 posts
  • Local Club: CV1 Mini's
Posted 03 June 2019 - 05:34 PM
Raptor can be applied over etch. I would stick a coat of 2k primer on first personally. I've used epoxy primer first and went wet on wet with the raptor. Bear in mind some epoxy primers state not to go over etch, well the one I use does anyway. Hope this helps you.
Technical data sheet here.
https://www.nakatanenga.de › media › pdfPDF
technical data sheet & process guide - ...
Edited by cookie4343, 03 June 2019 - 05:39 PM.
#3 Daz1968
Daz1968
  • 2,058 posts
Posted 03 June 2019 - 08:40 PM
I used epoxy mastic followed by raptor, never had any problems. Just epoxy best over abraded steel, so I roughed the floor with p80 on a da.
#4 cookie4343
cookie4343
  • 2,257 posts
Posted 03 June 2019 - 08:44 PM
Pretty much the same a I did but was just 2k epoxy not epoxy mastic. Seems tough enough to me, time will tell.
