Hi guys. Anyone on here ever use the EZ oil drain valve on their Mini and if so what do you think of them and what size did you use. There are other brand names too, but just used this one as an example. I have one on my R56 and like it but dont have one on my 1990 classic Mini. Pro's Con's. Thanks
Ez Oil Drain Valve
sparkymae
, Jun 11 2019 05:50 PM
7 replies to this topic
Posted 11 June 2019 - 05:50 PM
Posted 11 June 2019 - 08:04 PM
Pro: easy to drain your oil
Con: easy for someone else to drain your oil for a laugh
Posted 11 June 2019 - 08:39 PM
You will need to take the plug out anyway to remove all the lumps of gearbox and bearings in the sump
Con; Loss of the magnetic plug feature of the stock drain plug.
Posted 11 June 2019 - 09:15 PM
I like the idea on a modern car or something with a sump guard. But on a standard mini it seems quite exposed...
If you want quick easy oil changes maybe an oil extractor? One of them pump things
Posted 11 June 2019 - 09:21 PM
It's like a solution to a problem that doesn't exist. I wouldn't bother
Posted 11 June 2019 - 09:23 PM
Nah.
Posted 12 June 2019 - 11:38 AM Best Answer
All good points, thanks :)
