Disconnecting Fuel Lines From Throttle Body ?‍♂️
14 replies to this topic
#1 slayerofcows
slayerofcows
  • 25 posts
Posted 11 June 2019 - 07:28 PM
Hi all,
‘96 1275 SPi
I’m trying to get inlet manifold out but really struggling to get these union bolt things off for the past few days. They won’t budge at all. I’ve tried some wd40, elbow grease, more wd40 and more elbow grease.
Is there a knack to this as I feel I’m doing something wrong?
If I can’t get them off, could I just disconnect the hoses off further back or is this likely to make a right mess?
Cheers!
#2 slayerofcows
slayerofcows
  • 25 posts
Posted 11 June 2019 - 07:30 PM
Should have said, I’ve been using two spanners. One to hold the small one in place and the other to try and turn the big one anti-clockwise!
#3 Pops_Guild
Pops_Guild
  • 363 posts
Posted 11 June 2019 - 11:51 PM
Whatever you disconnect, you’ll get fuel coming out. Just have cloths ready. I’ve never disconnected those fixings and instead have always taken the rubber pipes off further back. Never liked the risk of messing the pipes up, they’re no longer available.
I block the rubber pipes up with drill bits and clamp.
#4 viz139
viz139
  • 682 posts
  • Local Club: Irish Mini Owners Club
Posted 12 June 2019 - 08:40 AM
I always disconnect at the rubber hoses. I have seen two SPi where the pipe was kinked just after the nut were the pipe twisted with the nut being opened.
#5 Dutchdave's25
Dutchdave's25
  • 105 posts
Posted 12 June 2019 - 09:15 AM
I too have seen many cars with twisted pipes, nevertheless, they can be disconnected, just make sure the bracket next to the rubber fuelhoses is off. (that will allow the pipe to move and should stop it from twisting) if you need anything for your injection housing i've got some spares.
#6 MatthewsDad
MatthewsDad
  • 819 posts
Posted 12 June 2019 - 11:28 AM
Might be an opportunity to replace the hoses too, if they're original? I didn't have any problem disconnecting at the fuel lines, using two spanners as you suggest. iirc there's an o ring seal to keep a look out for if you do detach the fuel lines from the injector body. Good luck.
#7 slayerofcows
slayerofcows
  • 25 posts
Posted 12 June 2019 - 08:20 PM
Thanks all,
A bit more elbow grease tonight got one of them off but the other still won’t move.
Perhaps also helped that I bought a size 15 spanner which fits better so using a 15 and a 17 together.
I’ve sprayed more wd40 on it this evening and ordered some hose clamps which arrive tomorrow so if I can’t get the other off tomorrow then I’ll take that one off at the hose. Maybe when I’ve got the throttle body on the bench I’ll be able to get at it from some different angles!
Will let you know what happens (or if I need some spares!)
#8 FlyingScot
FlyingScot
  • 2,664 posts
Posted 13 June 2019 - 02:25 AM
My own 2 cents....
Don’t use WD40 it’s crap at releasing rusting or stuck stuff(it’s fish oil base).
Use PlusGas and you’ll find most of these type of tasks easier.
FS
#9 slayerofcows
slayerofcows
  • 25 posts
Posted 13 June 2019 - 07:57 AM
Alright just ordered some of that from amazon so that’ll arrive tomorrow and I’ll give some of that a go!
#10 MatthewsDad
MatthewsDad
  • 819 posts
Posted 13 June 2019 - 08:03 PM
Might take a few days / applications to work, but it is good stuff.
#11 slayerofcows
slayerofcows
  • 25 posts
Posted 13 June 2019 - 08:55 PM
Huzzah!
#12 Steve220
Steve220
  • 5,066 posts
  • Local Club: BMC
Posted 14 June 2019 - 01:33 PM
I know its a bit late now, however heat does help. Obviously any flames are out of the question O_O  However pouring boiling water over helps a little.
#13 slayerofcows
slayerofcows
  • 25 posts
Posted 14 June 2019 - 03:52 PM
No doubt this ain’t gonna be the last of my seized up bolts and screws so all advice welcome!
#14 slayerofcows
slayerofcows
  • 25 posts
Posted 14 June 2019 - 05:11 PM
Also a bit late this but I’m sure it too will serve useful in time to come.
#15 kommander
kommander
  • 210 posts
Posted 17 August 2019 - 01:00 AM
I always use a flare nut spanner and an open ended spanne.
