So the actuator goes to the turbo and I’ll have a bleed valve between the two.
In the pic, what would the other turbo outlet for
Posted 13 June 2019 - 07:39 PM
Posted 13 June 2019 - 07:53 PM
Posted 13 June 2019 - 11:32 PM
Posted 14 June 2019 - 08:54 AM
Thought I'd add it can still be useful, if you fit a bleed valve you can use it to adjust (upwards only) when the waste gate opens. Or you could fit the solenoid valve and control it with megajolt or similar.
Posted 14 June 2019 - 09:11 AM
Posted 15 June 2019 - 07:49 PM
Posted 15 June 2019 - 10:21 PM
Posted 16 June 2019 - 11:19 AM
one side to the waste gate, the other side was used to bleed off pressure and delay the waste gate opening until you had more boost.
Either way the waste gate actuator itself sets the lower limit. From memory it's only 3-4 psi with the original Metty Turbo one. If you want more boost you'll need a bleed vent or a different actuator can.
Posted 16 June 2019 - 04:04 PM
Posted 16 June 2019 - 04:17 PM
Posted 16 June 2019 - 06:15 PM
