Hi real quick one,anyone had an issue using the upol tiger seal seam sealer and raptor tintable stone chip ?
Any reactions ?
Tiger Seal And Raptor Stone Chip ?
leepol83
, Jun 15 2019 08:52 PM
4 replies to this topic
Posted 15 June 2019 - 08:52 PM
Posted 15 June 2019 - 09:09 PM
You will be fine as long as you let the sealer dry first before you add the stone chip as sealer is air dried and raptor is a chemical cured system.
Posted 15 June 2019 - 11:10 PM
As above.
Raptor and Tiger seal are both PU based so are compatible.
I have just sealed up a job using a Wurth PU seam sealer and the Raptor worked fine over the top without any reactions or other problems.
Ben
Posted 16 June 2019 - 01:36 PM
Main reason I used raptor on my mk2 was being 2k and low solvent content it doesn’t really react with anything, my previous mk1 project when I used high solvent 1k stonechip, upol gravitex I had it reacting with brushable seam sealer and tigerseal but think it was the solvent softening the underlying materials. I had no such problems with raptor so would use again.
Posted 17 June 2019 - 07:35 PM
Brilliant cheers guys really appreciate it ?????
