Top Dash Pad Removal ...help
8 replies to this topic
#1 Rallye67
Rallye67
  • 46 posts
Posted 16 June 2019 - 04:13 PM
:ohno:   Big help needed still   1998 cooper top dash pad removal  , got the nuts off the 3 bolts but theres no way the fixed bolt in the centre will clear enough to get the top dash out , tried everything .
Can anyone please help . 2nd pic is from underside of the dash
Edited by Rallye67, 16 June 2019 - 04:14 PM.
#2 Its a min
Its a min
  • 284 posts
Posted 16 June 2019 - 04:25 PM
The easiest way is to remove the windscreen but if you don't want to do that, it should still come out but with a struggle as it pushes against the windscreen rubber.
Edited by Its a min, 16 June 2019 - 04:26 PM.
#3 Tupers
Tupers
  • 4,156 posts
Posted 16 June 2019 - 04:35 PM
They’re incredibly tricky to remove with the windscreen in place.
You can in some cases hold onto the dash pad and rotate it towards yourself (windscreen end up, dash end down) but I’ve found it’s normally quicker to remove the screen.
#4 Rallye67
Rallye67
  • 46 posts
Posted 16 June 2019 - 05:07 PM
never removed windscreen how hard is it ?
#5 MIGLIACARS
MIGLIACARS
  • 2,057 posts
Posted 16 June 2019 - 05:15 PM
The first one i did came out so easy with the screen in.
but ive never managed to get any more out with screen in.  I even began to think I imagined doing the first one.
#6 Rallye67
Rallye67
  • 46 posts
Posted 16 June 2019 - 05:28 PM
ITS OUT !!!!!   TF 4 THAT !!!!   think going to need a new top rail though :shifty: can you buy these  separate ?
is this it ?
http://www.minispare...px|Back to shop
Edited by Rallye67, 16 June 2019 - 05:32 PM.
#7 luismx123
luismx123
  • 525 posts
Posted 16 June 2019 - 05:34 PM
its not that hard to remove.
First, open all 3 bolts.
Second, push the middle bolt backwards - this will bend the "U" shape bolt holder towards the bulkhead
Third, pull dash out.
When installing, reverse and bend back the bolt frame :)
#8 Rallye67
Rallye67
  • 46 posts
Posted 16 June 2019 - 06:36 PM
think the upper dash rail is going to need to be replaced ,  does the edge go under the window rubber its hard to see.
#9 Tupers
Tupers
  • 4,156 posts
Posted 16 June 2019 - 07:37 PM
Yes the scuttle panel, bulkhead and top dash rail are all spot welded together and form the seam that the windscreen seal sits on.
