Miglia/libre Rules And Regs
2 replies to this topic
#1 Gaz66
Gaz66
  • 937 posts
Posted 18 June 2019 - 01:08 PM
Could someone point me in the direction of some online info regarding the rules and regs of these classes?
Gaz
#2 mab01uk
mab01uk
  • 12,453 posts
Posted 18 June 2019 - 06:24 PM
Mini 7 - 2019 Regulations
http://www.mini7.co.uk/downloads.php
TR.5.18
MINI LIBRE (Technical Guidelines - 2019) are on Page 24 of the Mini Seven/Miglia Technical Regulations download:-
TR.5.18.1 All cars and drivers must comply with Motorsport UK Safety requirements (see TR.5.3).
TR.5.18.2 Cars must follow the silhouette of the classic saloon Mini; allowances will be made for modifications to the bonnet for clearance. However, spaceframe, van, pick-up and clubman variants will not be eligible. Grille, surrounds and bumpers must be retained. Steel roof mandatory. Door material is free. Any form of modified or lightened door must have a reinforcing panel and either be solid foam-filled or filled with carbon/aluminium honeycomb inserts.
TR.5.18.3 An A-Series engine block and gearbox is mandatory. The maximum engine capacity shall be 1400cc. Forced induction is prohibited (i.e. no turbochargers or superchargers). Any form of sequential control/gearshift is prohibited (see TR.5.9.2.3).
TR.5.18.4 10-inch diameter wheels are mandatory. TR.5.18.5 Dunlop tyres are mandatory. .
TR.5.18.6 The minimum running weight of the car, including driver is to be as follows: i) 5-port iron head, as Miglia (i.e. 660 kg). ii) 7-ports, 8-ports and 16 valves, 20kg above Miglia minimum running weight (i.e. 680kg). Additional ballast may be added to selected cars, subject to performance
TR.5.18.7 M7RC sponsor decals, plus Mini Libre windscreen header and door squares are mandatory.
TR.5.18.8 Drivers’ rear quarter window names must follow the M7RC font and size (see TR.5.17).
TR.5.18.9 Race numbers will be allocated on a three-figure basis (excluding #700-799).
TR.5.18.10 The M7RC reserves the right to add further detailed technical guidelines during the season.
http://www.mini7.co....ations-2019.pdf
Edited by mab01uk, 18 June 2019 - 06:28 PM.
#3 Gaz66
Gaz66
  • 937 posts
Posted 18 June 2019 - 06:56 PM
Thanks, just what I wanted :-)
