What Small Form Factor Rust Removal Tools Do People Use?
8 replies to this topic
#1 MikeRotherham
MikeRotherham
  • 983 posts
Posted 22 June 2019 - 10:19 AM
Attempting to use power tools to remove rust in a confined space I wondered what do othe people use?
I have a conventional drill with various brushes that just seem to do little more that polish the metal or my favourite a polycarbide abrasive disk that removes rust and paint without removing too much metal and leaves a good finish.
https://www.amazon.c...sc=1&th=1&psc=1
I also have a Bosch Multipurpose tool with the delta shaped head with abrasive of various grits very effective but can thin the metal quickly if not too careful.
Both those tools are quite bulky in confined spaces.
The smallest I have is a Dremel with a flexible drive hand piece but apart from the little cylindrical abrasive rolls provision for rust removing on slightly bigger areas isn't brilliant.
Thought about perhaps getting an air powered mini disk sander.
What do other people use?
Edited by MikeRotherham, 22 June 2019 - 01:11 PM.
#2 Stu1961
Stu1961
  • 634 posts
  • Local Club: Still Looking
Posted 22 June 2019 - 02:23 PM
Sounds like you are at the stage where you have removed most of the rust using the tools you have at your disposal, what's left can be removed by applying a rust remover (not a rust converter) I use Bilt Hambers Deox Gel. I find the process very labour and time consuming but the end result is well worth it, most will tell you to follow the instructions to the letter though I must admit I do deviate from them a bit.
Apply/spread it on as per the instructions then cover with cling film to stop it drying out, I then leave it alone for 24 hours once this period has passed I then get to work on it using a small hand held wire brush (tooth brush size) you can see that it is working as the Deox Gel will turn from a light beige colour to a rusty brown, once I'm happy I have vigorously brushed  the whole area I cover it again with cling film as even though its dirty and now contaminated the solution will carry on doing its job then repeat the wire brushing process again.
The only downside to using the product is that soapy water has to be used to remove it, this can be a pain especially when using it close to seams so once its all off I dry the area immediately with a heat gun, whatever you do don't let the solution dry out as its almost impossible to remove without using water or a wire brush, white spirit or cellulose thinner wont touch it once its dry.
The tools you are using at present are probably no different to what most others use, I have found that in confined spaces a powerfile can be useful for removing scale as you only need to apply it very lightly you don't want to be removing good metal (Cannot stress that enough) the action of the moving belt does all the work for you. As for wire wheels I find the best ones are those that cut on their circumference/outside diameter the sizes I use are 2" and 3" they out last all the others and are more effective for longer especially if used at a slow speed and not flat out.
#3 Bobbins
Bobbins
  • 1,502 posts
Posted 22 June 2019 - 05:07 PM
Dremel and spiraband abrasive rolls followed by Deox Gel.
#4 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,066 posts
  • Name: Neil
Posted 22 June 2019 - 06:06 PM
If you have a compressor then either a right angle or straight die grinder along with various carbide burrs will do the job. My tools of choice.
#5 Spider
  • 15,059 posts
Posted 22 June 2019 - 08:15 PM
Sometimes in those small areas Abrasive Blasting or one of the Acids is about the only thing that will get right in.
#6 Chris M
Chris M
  • 167 posts
Posted 22 June 2019 - 08:32 PM
I’ve got an air belt sander that’s great for small areas as it’s only about 10mm wide.
#7 r3k1355
r3k1355
  • 585 posts
  • Local Club: East Anglia
Posted 24 June 2019 - 10:27 AM
The water part has put me off using it before, it just seems like thats exactly what is needed to encourage the rust back?
#8 pete l
pete l
  • 1,374 posts
Posted 24 June 2019 - 12:54 PM
I use deox gel to remove / soften the old deox gel.
I then wipe it down with some paper and then wipe it over with this :
https://www.bilthamb...tments/atom-mac
Edited by pete l, 24 June 2019 - 12:55 PM.
#9 MikeRotherham
MikeRotherham
  • 983 posts
Posted 24 June 2019 - 02:45 PM
Thanks for the info.
Not quite at the stage to use the Deox Gel but have used it quite a bit before now. Much better than products that just convert the surface rust to a blue/black covering.
