Blocked Passage After Thermostat
engine
Best Answer phillrulz , 23 June 2019 - 09:09 PM
Thats the bypass pipe i belive, round the back of the head there will be a piece of pipe sticking out the head facing down towards the water pump / pumphose
Go to the full post
9 replies to this topic
#1 Echan42
Echan42
  • 43 posts
Posted 23 June 2019 - 04:09 PM
When fitting a thermostat in my recently acquired 1972 1000ccmini I found this passage blocked with gasket sealant, any idea why the old owner would do this and what effect this would have on the engine?
Edited by Echan42, 23 June 2019 - 08:39 PM.
#2 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,087 posts
  • Name: Neil
Posted 23 June 2019 - 05:40 PM
Hi,
the link you have posted does not work.
When using Imgur please use this for copying your picture over.
BBCode (message boards & forums)
That will post your picture directly to the forum rather members having to go via the link.
#3 Echan42
Echan42
  • 43 posts
Posted 23 June 2019 - 08:39 PM
Thanks! I updated
#4 phillrulz
phillrulz
  • 617 posts
Posted 23 June 2019 - 09:09 PM   Best Answer
#5 phillrulz
phillrulz
  • 617 posts
Posted 23 June 2019 - 09:13 PM
http://www.theminifo...hose/?p=2484408
Here is a picture of the back of the head
#6 cal844
cal844
  • 9,660 posts
  • Local Club: TFMOC
Posted 23 June 2019 - 09:58 PM
I agree with Philrulz
That does look like the bypass hose stub has been rather crudely blanked
How that engine hasn't overheated due to water loss is beyond me
#7 nicklouse
  • 18,718 posts
Posted 23 June 2019 - 10:59 PM
the stat housing surface is not looking fresh.
i would be rectifying that blockage soonish and then getting the engine flushed through with some cleaner. idf you are not planning on pulling the power unit soon.
#8 Echan42
Echan42
  • 43 posts
Posted 24 June 2019 - 08:39 AM
It definitely is the bypass hose, why would someone purposely block it?
Yep, you're absolutely right, I can only.omagime the rest of the circuit is in similar condition, I'll be looking into buying some additive to flush the engine asap
#9 cal844
cal844
  • 9,660 posts
  • Local Club: TFMOC
Posted 24 June 2019 - 09:08 AM
The reason the bypass hose may have been deleted is that the concertina type hoses are rubbish and a previous owner fitted a non bypass pump?
#10 phillrulz
phillrulz
  • 617 posts
Posted 24 June 2019 - 03:17 PM
As Cal844 said, there is a bodge just as bad as glue together CV boots, you can get a concertina hose about 2" long that goes between the water pump and the head. They are known to fail. Maybe last owner had one blow and just siliconed it shut and swapped the pump for a non bypass type. Or maybe ordered wrong pump and just siliconed it closed.
Dont think there is any benifit with it closed just causes the head to warm up slower as the water cant circulate around the head it has to do the whole loop .
