Minnow Fish Carb Manifold Or Adaptor
35 replies to this topic
#1 ads7
ads7
  • 351 posts
Posted 24 June 2019 - 01:35 PM
Hi, just bought a minnow fish 1 1/4" carb, objective being better mpg from our 850 as part of a wider eco focused project I'm running. Better torque and power from this carb too.
According to the original designer it works better as a downdraught although after considering your helpful replies on this thread I'll be running as sidedraught - does anyone have an inlet manifold adaptor from HS2 to fit onto my existing minispares inlet ??
(We've run through various downdraft manifolds and I'm erring away from these)
Hope this is going to be an interesting project
Edited by ads7, 25 June 2019 - 07:29 PM.
#2 DeadSquare
DeadSquare
  • 3,151 posts
Posted 24 June 2019 - 04:45 PM
As I remember, A Reece Fish was a straight bolt off bolt on replacement for an SU.
#3 ads7
ads7
  • 351 posts
Posted 24 June 2019 - 06:48 PM
Hi it's an original minnow fish as opposed to the Reece fish - respective designers fell out with each other. Interesting read on the whole thing here
http://minnowfishcar...uk/full-history
Will update this thread when the item arrives in post
#4 ads7
ads7
  • 351 posts
Posted 24 June 2019 - 07:02 PM
By the way the bolt holes are aligned vertically, not the diagonal arrangement as per SU carb. Hope it's direct fit but very much doubt it
#5 imack
imack
  • 2,167 posts
Posted 24 June 2019 - 07:15 PM
1 1/4" SU's have a vertical bolt pattern.
1 1/2" hs4's are diagonal.
Edited by imack, 24 June 2019 - 07:17 PM.
#6 spraybeater
spraybeater
  • 468 posts
  • Local Club: Mcr
Posted 24 June 2019 - 07:24 PM
I remember back in the 60s one of the guys I ran about with and did some work for!
ran an 850cc Hillclimb/ sprint Mini with a Minnow fish Carb, if memory serves me
right it was a bit of a pain to setup.
I never met Bob Henderson but new quite a few people whom did and his Lochgilphead
base.
As far as manifold goes possible an Austin A30
Edited by spraybeater, 24 June 2019 - 07:26 PM.
#7 ads7
ads7
  • 351 posts
Posted 24 June 2019 - 09:13 PM
Thanks both for info on hole alignment/possible manifold -A30 is downdraught so looking good IF it will clear my lcb
#8 panky
panky
  • 1,792 posts
Posted 24 June 2019 - 10:15 PM
Morris Minors have HS2's so could be a possibility but obviously side draught
Edited by panky, 24 June 2019 - 10:16 PM.
#9 gazza82
gazza82
  • 3,017 posts
  • Local Club: TMF+
Posted 24 June 2019 - 10:44 PM
A30/35 Zenith inlet is bolted to exhaust manifold so unlikely to work with lcb ... some sort of hot spot
#10 DeadSquare
DeadSquare
  • 3,151 posts
Posted 25 June 2019 - 08:14 AM
The A30 inlet is rather small bore with sharp angles.
#11 spraybeater
spraybeater
  • 468 posts
  • Local Club: Mcr
Posted 25 June 2019 - 08:24 AM
If I remember correctly, it was quite a few years ago :shy:  we used the carb in a side draught orientation!
I suggested the A30 as a  possible because its down draught !
#12 Spider
  • 15,017 posts
Posted 25 June 2019 - 08:36 AM
Quite enjoyed that link, thanks, but the story, while likely in an overall way, is accurate, it doesn't 'add up'.
#13 Ethel
  • 26,008 posts
Posted 25 June 2019 - 09:27 AM
Going by the piccy in the link it looks like it'd be a nice diy project to make one, as long as you can get some tube bent to the right radius.
#14 viz139
viz139
  • 675 posts
  • Local Club: Irish Mini Owners Club
Posted 25 June 2019 - 01:17 PM
Could you adapt an SPi manifold to suit
http://www.leacyclas...m/lkb10477.html
#15 DeadSquare
DeadSquare
  • 3,151 posts
Posted 25 June 2019 - 02:15 PM
Because of the constricted height, a downdraft inlet will effectively have two elbows in 3 dimensions for the gas to flow through, where as a sidedraft could have a pair of shallow S's in 2 dimensions.
Edited by DeadSquare, 25 June 2019 - 02:37 PM.
