Maniflow Hiflow Inlet
Posted 25 June 2019 - 07:58 AM
Posted 25 June 2019 - 08:00 AM
Posted 25 June 2019 - 08:11 AM
The MG metro inlet manifold flows well but by virtue of having large ports. Good for 1275s and up but less so for small bore motors due to low port velocity so on a 998 you'll have less low down torque than you would have with a manifold that is more suited.
See what the others say about alternative manifolds.
Posted 25 June 2019 - 08:58 AM
I’ll have a look later for you as I have these manifolds and have run flowbench testing with both.
Phil.
Posted 25 June 2019 - 12:21 PM
Posted 25 June 2019 - 12:22 PM
I understand the points your making on velocity, Phil I’d be interested to see the test results you refer to if you get chance.
Does anyone know if the minspares version is basically the same animal or does this have better/worse characteristics?
Posted 25 June 2019 - 12:25 PM
Also interested in this. Just got myself the Yellow bible but inlets like the minispares/minisport arn't tested. How do they compare to the older type manifolds?
Posted 28 June 2019 - 10:44 AM
I notice in the same article he refers to Howley and Titan manifolds, seen these on eBay every so often, anyone know the port sizes on these compared to the MG and Minispares?
Posted 28 June 2019 - 11:35 AM
There is a graph in Vizard comparing flow, tho some of the manifolds I have never seen-but it's an old book.
I have never been disappointed with the Minispares inlet manifold.
Posted 28 June 2019 - 12:16 PM
Phil.
Posted 28 June 2019 - 02:53 PM
Posted 28 June 2019 - 04:21 PM
Phil.
Posted 28 June 2019 - 06:02 PM
Thanks for your help and advice much appreciated.
Posted 29 June 2019 - 07:00 AM
I have been assured that the Minispares manifold will be back in stock in about a week. (Here, have a pinch of salt.)
