Hi all,
998cc running twin HS2s.
I have set up the carbs as per SU instructions (i.e. set the jets to the bridge then down a turn or two, undo the idle screw then wind in one full turn etc) and it is idling very quickly, which I suppose it would before you start adjusting them.
The problem is that even when I back both screws off completely such that they aren't doing anything the idle is still too high (around 1400 - 1500).
I think that I need to lean the carbs off a bit, but when I've tried this before it doesn't significantly reduce the idle speed. The only thing I have found that does impact it is the timing (which obviously isn't a solution). The carbs have been serviced, and I'm fairly confident that the spindles aren't leaking.
Does anyone have any suggestions as to why I run out of adjustment on the idle screws before it gets close to a sensible idle speed?
Thanks,
Dan
TheHippo
