Top Coat Over Zinc Galvanised Subframe
7 replies to this topic
#1 Curley
Curley
  • 471 posts
  • Local Club: Not MINI friendly
Posted 26 June 2019 - 03:38 PM
I've had my rear subframe galvanised in a hot zinc dip and looking for a advise on how to apply a black top coat. Is there any special steps I need to take before applying a top coat?
#2 ukcooper
ukcooper
  • 1,625 posts
Posted 26 June 2019 - 05:03 PM
any paint you want I guess , how did you stop the frame twisting we tried one time  and it was out by miles...…...if you not tried it on the car I would to see if it fits any more as that's y most people don't do it   ?????????????
Edited by ukcooper, 26 June 2019 - 05:04 PM.
#3 Daz1968
Daz1968
  • 2,058 posts
Posted 26 June 2019 - 06:19 PM
The is a special product called t wash, this is applied to the galvanised coating and left approx 1 hour, then washed down with water and dried off. It turns the zinc black and it can then be painted. We use it at work and it is effective.
#4 DeadSquare
DeadSquare
  • 3,188 posts
Posted 27 June 2019 - 07:41 AM
May suggest that you reconsider painting it black.
It is dark under there, and if you ever want to do something, I have found it much more useful to have a lighter colour.
I actually paint mine white, but it very soon becomes the colour of the local mud, so my next one will be a sandy colour.
I will continue to paint the front subframe and the lower engine bay, white.
#5 Spider
  • 15,136 posts
Posted 27 June 2019 - 11:03 AM
Usually with anything that's been Galvanized, you'll have better success in having paint stay put the longer you leave it, with a month being the minimum that's usually recommended.
De-gassing it can also help a lot. This is easiest done if you can get it in to an oven at around 120 - 150 Degrees C for about 2 - 8 hours.
#6 onefastmoke
onefastmoke
  • 363 posts
Posted 30 June 2019 - 05:40 PM
Buzzweld "Galv in one" can be painted straight onto galvanised metal   http://www.buzzweld....in-one-gio.html
#7 Daz1968
Daz1968
  • 2,058 posts
Posted 30 June 2019 - 10:37 PM
this is the product I was referring to
https://rover.ebay.c...tm/161195724751
#8 Curley
Curley
  • 471 posts
Posted 01 July 2019 - 08:04 PM
ordered  :D
Edited by Curley, 01 July 2019 - 08:04 PM.
