Reducing Swarf In The Gearbox
4 replies to this topic
#1 Chew
Chew
  • 21 posts
Posted 27 June 2019 - 02:10 PM
Hi everyone, just wondering what the best way would be to ensure as little swarf remains in the gearbox after installing a helicoil with the engine in situ. I don't really have the opportunity to take the engine out yet and the repair to the sump thread is needed asap.
Cheers.
#2 mini13
mini13
  • 3,811 posts
Posted 27 June 2019 - 02:29 PM
Grease the drill bit and tap before use so the bits will stick to it, also you can dump a bit of deseil/petrol/parafin through to wash through the last bit. As its ally any odd little bit will be pretty soft so wont cause an issue
#3 Steve220
Steve220
  • 5,068 posts
  • Local Club: BMC
Posted 27 June 2019 - 03:52 PM
As above. I repaired a mate's gearbox and ran some oil through after, seemed to get a load out.  Boroscoped after and couldn't find any.
#4 TheFabMini
TheFabMini
  • 459 posts
Posted 27 June 2019 - 04:51 PM
Is the helicoil being used on the sump plug thread??
When I did mine I flushed it out with about 1l of thin 0w30 oil I had laying about.
Also I had a magnetic stick thing I shoved in the sump hole and prodded about which picked up some extra bits
#5 alex-95
alex-95
    I am THE CLAMP MAKER
  • 6,042 posts
Posted 27 June 2019 - 05:19 PM
I would get the vacuum cleaner out and suck it out.
You got an aluminium magnet?  :lol:
