Hi all, generally it's starts fine,but recently the fuel pump doesn't kick in after turning on the ignition,I gave the fuses a little clean and seemed to work but it's happening more frequently and takes more attempts with taking the fuse out, maybe relays or fuel pump on its way out, it never stops while running only starting the engine, any ideas? Thx
1995 Spi Cooper Fuel Pump Issues
tatomb66
, Jun 28 2019 08:24 AM
6 replies to this topic
Posted 28 June 2019 - 08:24 AM
Posted 28 June 2019 - 05:16 PM
Generally you only hear the fuel pump when you first turn ignition on, it could be the pump if someone has let it run out of fuel, this means you will have to take the tank out to change it Try swapping the two yellow relays around which are next to the fuel shut off on the bulk head.
Posted 28 June 2019 - 06:48 PM
Hi, I've changed both relays today and still the same, started no problem, drove it a few miles turned it off then tried to start it and no buzz from fuel and it wouldn't start again, maybe need a fuelpump...
Posted 28 June 2019 - 07:20 PM
Check power is going to the pump with a multimeter, is your immobiliser tuning off properly with the fob?
Posted 28 June 2019 - 07:28 PM
I've been advised to check this, and the immobiliser seems to go off, do these have issues, (immobiliser)?
Posted 28 June 2019 - 07:30 PM
I've been advised to check the power, the immobiliser seems to turn off, do thses have issues?
Posted 29 June 2019 - 07:46 AM
