My Minis Front End Is Sitting Far To High?
Posted 11 July 2019 - 07:27 AM
Cheers se
Posted 11 July 2019 - 07:43 AM
New rubber cones do settle, give it a few weeks and then check again.
Posted 11 July 2019 - 09:38 AM
Hi
No need to do any thing drastic. I have known them to take 2 months sometimes, but they will definitely settle down as Moke rightly says
Posted 11 July 2019 - 10:04 AM
The front end of my mini is sitting about 3inches + higher than the rear. My hi/Los are set to the lowest they can be. All the suspension is brand new so is it because the cones need bedding in or will the adjustable arms bring it down?
Cheers se
By "adjustable arms", presumably you are referring to the lower front suspension arm ?.
Altering their length will not affect the ride height.
Posted 11 July 2019 - 12:14 PM
What knuckle joints have you fitted.. I assume with new cones you fitted new knuckles...I believe they are the same front and rear but later cars 1990 onwards had a built in spacer for extra ride height clearance.... have you bought the later 1990 onwards ones for a pre 1990 mini perhaps ?
Posted 11 July 2019 - 07:49 PM
Posted 11 July 2019 - 08:00 PM
In my experience the best thing you can do is to use it! It'll settle quicker.
I agree
Posted 11 July 2019 - 08:59 PM
Posted 12 July 2019 - 07:49 AM
Posted 12 July 2019 - 08:13 AM
3" is a lot to expect to settle!
Posted 13 July 2019 - 09:43 PM
The rubber cones will have a big impact - i know i replaced all mine at the same time.
The problem is they do settle, but they need weight to do it. As my Mini only ever really has one person, the drivers side is actually lower than the passengers side. For quite some time the arse was so high i was accursed of lowering the front for the dragster look!
I was told to drive around with bags of concrete to weigh down the other side, but it made no difference.
Also just for reference there are actually two rubber cones both claiming to be Genuine. One is the prototype version, the other is the one that actually sent on the production model. I can't remember which way round it is, but Mini Spares sell one and Mini Sport sell the other.
Posted 14 July 2019 - 12:53 AM
One firm bought the patent but manufacture to their own standards, are made by Avon.
The other is made on the factory tooling and using the same factory rubber recipe so in effect, are exact copies of the OEM item.
Posted 14 July 2019 - 07:13 AM
Which are which and what ones are better?
Posted 14 July 2019 - 08:01 AM
To be quite fair, the Avon ones are ~ OK ~ but from tests I've done, definitely softer than the originals and don't last as well (before sagging).
I prefer those made to factory specs.
Posted 14 July 2019 - 09:13 AM
Edited by CityEPete, 14 July 2019 - 09:13 AM.
