Bulkhead Blanking Plate With Heater Pipe Stubs
7 replies to this topic
#1 johnR
johnR
  • 2,297 posts
Posted 17 July 2019 - 07:13 PM
I don't really like the idea of my heater pipes passing vertically through the bulkhead blanking plate (potential for fluids to run down them) and wondered if anyone has made a custom plate - ideally with 1/2" stubs above and 5/8" stubs below to remove the need for reducers elsewhere in the lines?
#2 KTS
KTS
  • 2,426 posts
Posted 17 July 2019 - 08:10 PM
how about something like this ?
#3 KRM_Simon
KRM_Simon
    Previously known as 'bigsimonb'.
  • 165 posts
Posted 17 July 2019 - 08:26 PM
As above, have used them and they are good. They do all sorts of sizes and you can get ones with wider spacing.
#4 Icey
Icey
  • 1,551 posts
Posted 17 July 2019 - 08:33 PM
I used a couple of AN bulkhead and barb fittings to go through the blanking plate:
And on the inside...
Edited by Icey, 17 July 2019 - 08:34 PM.
#5 nicklouse
  • 18,591 posts
Posted 17 July 2019 - 08:49 PM
DSN have suitable connectors.
#6 johnR
johnR
  • 2,297 posts
Posted 17 July 2019 - 09:27 PM
Yes, those look good - I could remove the link and bolt the stubs direct to my blanking plate. Thanks, great suggestion.
#7 KRM_Simon
KRM_Simon
  • 165 posts
Posted 18 July 2019 - 05:00 AM
The individual stubs have a hexagonal section where they sit in the link to stop the spinning as you tighten them so this may cause a slight issue when you do as you say and they will sit a little proud of the bulkhead.
#8 johnR
johnR
  • 2,297 posts
Posted 18 July 2019 - 07:12 AM
I might start with a blank plate and form my own hex holes.
I have a thermostat head steady that goes over the blanking plate and the flanges would be sitting in (and virtually flush with?) the heater pipe holes in that.
