Rear Subframe Again.
1 reply to this topic
#1 nollyd
nollyd
  • 663 posts
Posted 20 July 2019 - 12:51 PM
hi all.in the process of starting to restore an 87 mini,i knew the healboard needed doing but more rotten than i anticipated,
i have a full length genuine heel board.my problem is the subframe mounting points are cracked and moving on my car so using bolt holes as reference points is a no go.
whats the best way to ensure the new panel is in the correct position before welding,need as much info as poss on this one guys,ref points etc.
cheers all.
#2 DeadSquare
DeadSquare
  • 3,375 posts
Posted 22 July 2019 - 02:55 PM
What do you mean by   "The subframe mounting points" ?
