If you can afford it, get an electric Morris Minor one and mount it near the wiper motor.
Take the electric from somewhere like the dash illumination switch, so that you can turn the pump off. If someone drives the car off, they only have a carb full of fuel before the engine dies.
I did try a Morris Minor Pump and in fact, put up with it for a about a year. They only have an output pressure of 1 PSI, I don't know why they are so low and the new pumps aren't adjustable in output pressure.
The car would run OK with this pump however I have a filter just down stream of it and as soon a 1 speck of crud would get in to the filter, the car would starve for fuel.
I used this pump as I needed a long line sucker pump, due to the arrangement of the fuel tanks and the only place I had left to fit a pump it was up under the passenger's side parcel tray.
I've since swapped out for one of the German Made SU copies that Mini Spares sell, done around 20 000 km with that now and hasn't missed a beat - yet.
I'm sure in time, as the pump wears that it will 'prematurely' let me down as it's not rated as a sucker pump and I'm using it a way that it's not designed for, but so far, I'm happy.
