Valve Guide Seals
12 replies to this topic
#1 croc7
croc7
  • 810 posts
Posted 24 July 2019 - 06:44 AM
On all eight or just intake?
#2 Spider
  • 14,875 posts
Posted 24 July 2019 - 06:50 AM
8
#3 OzOAP
OzOAP
  • 385 posts
Posted 24 July 2019 - 07:01 AM
I use 8 but take springs off exhaust seals
#4 r.tec
r.tec
  • 184 posts
  • Local Club: SfG Schoenau
Posted 24 July 2019 - 07:39 AM
I only use them on the inlet valves. Exhaust valves get much hotter and the rubber deteriorates much faster. Then the inlet channels are under suction while the exhauts are unter pressure.
#5 whistler
whistler
  • 1,793 posts
Posted 24 July 2019 - 08:52 AM
Why?
#6 carbon
carbon
  • 2,590 posts
Posted 24 July 2019 - 07:02 PM
Why?
I do similar, put old part-worn seals on the exhaust guides. If I don't put them on I get clouds of blue smoke on start-up and much higher oil consumption, but at the same time I want some oil to get to the guide.
The idea that exhaust gas pressure will keep the oil from going down the exhaust guide has never worked in any of my (admittedly old) engines. And before anyone asks this is the same even when uing PCV and slightly negative crankcase pressure.
#7 imack
imack
  • 2,110 posts
Posted 24 July 2019 - 07:31 PM
Intakes only for me on MED offset valve head. No visible smoke on start up or when running on this engine.
Previous engine with Longman offset valve head only had intake seals too but always smoked at idle, especially if facing downhill and oil running towards guides, never smoked pointing up hill with oil running towards push rod holes.
#8 croc7
croc7
  • 810 posts
Posted 25 July 2019 - 05:35 AM
Don’t like the idea of a smoking exhaust, but can understand the need to oil the exhaust valve and guide.
#9 Spider
  • 14,875 posts
Posted 25 July 2019 - 07:03 AM
The issue I have found with any oil going down the Exhaust Valve Stem is that it does burn on the seats and cause pitting of them. The Oil will also burn on the stem, with the ash being abrasive.
While most of the time, there is a positive pressure in the exhaust port, there's isn't always so. Oil will get drawn down.
#10 hhhh
hhhh
  • 422 posts
Posted 25 July 2019 - 02:22 PM
I would think that the moment when the exhaust valve closes, there will be negative pressure at the guide as the last gases rush out the exhaust system.
#11 Magneto
Magneto
  • 889 posts
  • Local Club: KC MINI Club
Posted 25 July 2019 - 03:31 PM
I do all 8, I think on street driven cars as compared to race engines it works just fine.
#12 Cooperman
  • 23,286 posts
Posted 25 July 2019 - 03:44 PM
I just fit to all 8. Always have and always will.
Can't see any advantages from not fitting to the exhausts.
#13 Steve220
Steve220
  • 5,045 posts
  • Local Club: BMC
Posted 25 July 2019 - 04:38 PM
I fit all 8 ?
Edited by Steve220, 25 July 2019 - 04:38 PM.
