To fit a 1275 auto block to a manual, apart from drilling the dipstick hole, there are a few mods needed to oil plumbing:
1. Auto block doesn't have the drilling all the way from the oil pump to the relief valve.
2. Auto block has 2 holes in the relief valve seat `cotton reel' to let oil get into the main gallery, because the normal filter flange is blocked off with a plate- the motor's lube oil comes UP the banjo pipe from the auto trans to the motor.
3. Auto block pump mounting recess is .250" deeper than in a normal 1275 block.
AusMini Link:-
http://www.ausmini.c...hp?f=25&t=90470
