Rebushing Rockers.
13 replies to this topic
#1 Wiggy
Wiggy
  • 1,036 posts
Posted 30 July 2019 - 10:25 AM
Hello guys.
My rocker shaft recently broke, so I replaced it with the heavier duty one just to get me back on the road.
My rocker bushes are clearly knackered though, and I'd like to replace them.
There's not a great deal of info that I can find on doing it, but I understand that they need reaming.
Is this something I could do at home if I bought a reamer? Any other tips, methodology, or info would be most welcome.
Cheers. :thumbsup:
Oh, the rockers are the JCW 1.5:1 ones. I'm assuming that they'll use the same bushes as standard?
#2 ACDodd
ACDodd
  • Mini Docs
  • 2,743 posts
Posted 30 July 2019 - 11:51 AM
It can be done with a reamer but you need to ensure they are machined square
I bore mine on a lathe.
Ac
#3 Magneto
Magneto
  • 889 posts
  • Local Club: KC MINI Club
Posted 30 July 2019 - 11:01 PM
Hello guys.
I'd be more worried about why the rocker shaft broke! Any automotive machine shop can ream the bushes after you press them in.
#4 DeadSquare
DeadSquare
  • 3,101 posts
Posted 31 July 2019 - 06:14 AM
Without in any way wishing to impune your ability, a reamer is a precision tool and the result is as bad as the way it is used.
As Magneto queried, I will add.  If the shaft broke, how long before a rocker is fatigued and brakes ?
#5 Pigeonto
Pigeonto
  • 973 posts
  • Local Club: ISMOC
Posted 31 July 2019 - 07:00 AM
Ac
What AC says. It's a horrible job by hand and inaccurate.
I'm not even sure that a fixed reamer would do it in one pass, it's a while ago now but I used adjustable ream with several passes, each one with potential for mis-alignment
Oh, and yes, standard bushes, the greater offset is gained within the geometry of the rocker, not the bush
Edited by Pigeonto, 31 July 2019 - 07:04 AM.
#6 Wiggy
Wiggy
  • 1,036 posts
Posted 31 July 2019 - 09:13 AM
Thanks for the replies.
As to why the shaft broke; I assume I wasn't careful enough when tightening down the rocker assembly on one occasion. Plus double valve springs, and then a higher lift cam, it had had enough. The shaft was absolutely shot regardless of the break.
Hmmm, sounds like I should employ the services of experts with the correct tools.
Do they require reaming to 9/16" exactly, or is there a clearance range depending on the exact diameter of the shaft?
#7 DeadSquare
DeadSquare
  • 3,101 posts
Posted 31 July 2019 - 09:43 AM
The BMC workshop manual says that they should be reamed to between  .5630" and .5635".   (14.30 and 14.312 mm)
#8 Spider
  • 14,858 posts
Posted 31 July 2019 - 09:52 AM
The important aspect here is to be sure the Rocker Tip ends up parallel to the Bush Bore. You may or may not end up with this when reamed.
I do mine in the Mill.
#9 Wiggy
Wiggy
  • 1,036 posts
Posted 31 July 2019 - 06:03 PM
Food for thought.
Cheers for the feedback guys.
#10 carbon
carbon
  • 2,590 posts
Posted 31 July 2019 - 06:35 PM
I would suggest extreme caution using a high lift cam with high lift rockers. Don't rely on assumptions - measure, measure, measure
Why emphasise this point? If you assume the rocker ratio is 1.5 then you may be in for a surprise. I have found that both forged and roller rockers can give lift ratios of up to 1.65 when used with 'standard lift' cams. And that means valve lift of 10.5mm
If you then add in a high lift cam you could be seeing valve lift approaching 12.5mm. That's not excessive, but if you don't have the right sort of valve springs fitted you could go coil-bound. And when that happens things tend to break, bend, or wear out very fast.
Remind me again, what do you think happened to cause the broken rocker shaft. And had anything been changed recently?
#11 Wiggy
Wiggy
  • 1,036 posts
Posted 01 August 2019 - 11:58 AM
The cam had been changed recently. It's only a 274i. JCW double valve springs and rockers.
I don't believe I was careful enough when tightening down or removing the rocker assembly (they've been off a few times), and thus created a stress fracture at the weakest point (oil feed hole), on an already rather worn shaft.
#12 1963MKI
1963MKI
  • 163 posts
Posted 28 October 2023 - 03:43 PM
im looking at doing this at the moment. I have a mill and a lathe but am not sure how I can mount a pressed steel rocker with either machine to get them square.
#13 gaspen
gaspen
  • 946 posts
Posted 09 December 2023 - 11:52 AM
Hello
I am rebuilding a standard 850 engine which has the old pressed rockers. I will replace the bushes before the machine shop.
I have the 2A21 bushes from MiniSpares
I suppose this the correct position of the bush. The little groove is down to align with the oil holes on the shaft. Right ?
Attached File  image.jpg   61.39K   2 downloads
#14 1963MKI
1963MKI
  • 163 posts
Posted 15 February 2024 - 01:42 PM
at what angle do you insert the bushing into the rocker ? i.e. where does the split on the bush roughly line up with on the rocker ?
I have heard that the inner groove on the rocker should only align with the oil feed on the rocker shaft at a certain point so it pulses oil into the rocker as it opens and when the valve is closed, the oil hole shouldn't align with the internal groove.
    Bing (1)
