Anyone Come Across Arp Thermostat Bolts That Are Too Long
7 replies to this topic
#1 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
  • Local Club: Loan wolf
Posted 05 August 2019 - 06:51 PM
Bought these ARP Sandwich thermostat bolts and they are bottoming out. Anyone come across this. Bought from Minispares.
Attached File  20190805_164044_resized.jpg   30.96K   5 downloads
#2 nicklouse
  • 18,657 posts
Posted 05 August 2019 - 06:54 PM
Does depend on the thermostat set up you have as there are various different thicknesses out there.
Don’t like bolts there either. Prefer studs.
#3 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 06 August 2019 - 07:55 AM
Totally agree. Didn't realise there were longer studs available for the Sandwich plate
#4 Homersimpson
Homersimpson
  • 831 posts
Posted 06 August 2019 - 01:38 PM
Out of interest why do you prefer studs? I always found that the thermostat housing tended to sieze onto studs whereas bolts tended to be easier to come free?
#5 gav
gav
  • 700 posts
Posted 06 August 2019 - 03:17 PM
ARP initially designed them for the Metro setup I believe so they are Metro length, it doesn't help that the thread depth varies in the heads also :/ Some people cut them down slightly or use an extra washer.
#6 nicklouse
  • 18,657 posts
Posted 06 August 2019 - 04:34 PM
Always had issues with bolts. Seize up and then snap. Studs take nuts off apply a release agent (if needed) job done.
Also not a fan of tightening unc threads. (Unless in alloy).
#7 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 07 August 2019 - 03:28 PM
to be honest . I'll probably end up trimming them down a bit. Just need to make sure the bolt is actually bottoming out at the end as opposed to not having enough thread up the bolt.
#8 Curley
Curley
  • 471 posts
  • Local Club: Not MINI friendly
Posted 08 August 2019 - 01:33 PM
Those ARP bolts are designed for use with a sandwich plate on the Metro style spout. It's trivial task to cut them down to your required length (much cheaper and faster than buying ARP from catalogue), just use a scrap nut as guide to protect the threads & ensure you get a straight cut.
