Rear Lhs Brake Light Not Working
8 replies to this topic
#1 rubdub
rubdub
  • 76 posts
Posted 21 August 2019 - 06:15 PM
Hey guys,
So I have my NCT tomorrow (Irish MOT) and my rear left brake light is not working. The rear light itself is, but it goes out once I put my foot on the pedal. I just swapped the bulbs there and the same thing is happening. It also looks like the element itself has blown.
Any suggestions greatly appreciated!
Edit: The driver side rear and brake lights are both working ass they should.
Edited by rubdub, 21 August 2019 - 06:17 PM.
#2 g0myw
g0myw
  • Just Joined
  • 108 posts
Posted 21 August 2019 - 06:36 PM
i'm no auto electician - but I'd be checking all the earth return points..
#3 phillrulz
phillrulz
  • 617 posts
Posted 21 August 2019 - 07:55 PM
So , the tail light works, but when you put your foot on the brake tail light goes out and no brake light iluminates?
If this is so - its an earth issue, clean any rust off from the earth . You says the bulb looks blown but works if put in tail light so just clean earth and try again
Edited by phillrulz, 21 August 2019 - 07:59 PM.
#4 rubdub
rubdub
  • 76 posts
Posted 21 August 2019 - 08:25 PM
Thanks fellas!
Just looking at the handbook for the MPI, would the first place to check be the earth points C557/559 by the fuel tank?
#5 phillrulz
phillrulz
  • 617 posts
Posted 21 August 2019 - 09:10 PM
Thanks fellas!
Yup
#6 rubdub
rubdub
  • 76 posts
Posted 21 August 2019 - 09:21 PM
Awesome, thanks!
Glad I was planning to change my rear shocks anyway!
#7 rubdub
rubdub
  • 76 posts
Posted 23 August 2019 - 07:41 AM
Thanks fellas!
Yup
Hopefully will be chasing this down tomorrow.. but could that bad earth also be why my license plate light isn't working either?
Thanks again!
#8 phillrulz
phillrulz
  • 617 posts
Posted 23 August 2019 - 02:53 PM
Thanks fellas!
Yup
Thanks again!
Numberplate lamps use C557 so possible.  The rear of the car also uses C101/C483 which is in the cabin on bulkead / passenger footwell this connects front and rear looms. But most likely that earth is your issue.
Edited by phillrulz, 23 August 2019 - 02:55 PM.
#9 rubdub
rubdub
  • 76 posts
Posted 23 August 2019 - 08:57 PM
Brilliant! Thanks for all the help phillrulz!
