I'm currently diagnosing an SPi mini with poor idling issues. The car cuts out when put into gear.
My initial scan revealed a MAP sensor pressure of 101kPa, on inspection the vacuum hose from manifold to fuel trap was missing.
I replaced all hoses and the fuel trap,however the MAP gave a reading of 66kPa....it reads 33kPa on my mini which runs fairly decent.
The lambda sensor voltage also fluctuated a little, then sat at zero.
My next step will be to replace the lambda sensor. I am still concened about the MAP's value.
Is there anything else that can contribute to this poor MAP value?
