Gear Selection Strange Problem
Best Answer alex-95 , 25 August 2019 - 01:14 PM
Has the gear selector been stripped? the base plate may be on 180 degrees out.
Go to the full post
15 replies to this topic
#1 Nobby4minis
Nobby4minis
  • 16 posts
Posted 25 August 2019 - 01:10 PM
Hi Guys
   Heres a weird one for you. I have just rebuilt my rod change 4 syncro box and all went well.Checked it on the bench and all the gears went in ok by moving the selector rod by hand. Just put it back on the engine and now back in the car. Heres the strange thing - I have to lift the gear stick to get first and second 3rd and 4th ok but reverse goes straight in with out any lifting of the stick. There must be something 180 deg out . I checked the gear selector was the right way up and it is . Any ideas?
#2 alex-95
alex-95
    I am THE CLAMP MAKER
  • 6,041 posts
Posted 25 August 2019 - 01:14 PM   Best Answer
#3 Rorf
Rorf
  • 866 posts
Posted 25 August 2019 - 01:16 PM
Did you strip the remote gear selector mechanism as well??? Maybe you put the bottom plate in the wrong way round. On that plate is the raised ledge which prevents it going into reverse unless you lift the gear lever.
#4 Nobby4minis
Nobby4minis
  • 16 posts
Posted 25 August 2019 - 03:15 PM
the whole box was stripped and cleaned . What do you mean by the bottom plate?
#5 KTS
KTS
  • 2,459 posts
Posted 25 August 2019 - 03:31 PM
..the metal plate on the bottom of the remote (gear lever) housing
#6 Nobby4minis
Nobby4minis
  • 16 posts
Posted 25 August 2019 - 03:38 PM
oh that could be a good shout  it only goes on one way then?
#7 alex-95
alex-95
  • 6,041 posts
Posted 25 August 2019 - 03:45 PM
Yep, from memory the hole should be at the front... if yours is at the front then put it to the back :lol:
#8 Nobby4minis
Nobby4minis
  • 16 posts
Posted 25 August 2019 - 03:49 PM
ok will check it tomorrow and let you know. cheers
#9 KTS
KTS
  • 2,459 posts
Posted 25 August 2019 - 06:54 PM
..conveniently the plate will fit either way round  O_O
the correct way round is as Alex says;  hole to the front
#10 Nobby4minis
Nobby4minis
  • 16 posts
Posted 26 August 2019 - 10:48 AM
that was the answer cheers for you help
#11 leepol83
leepol83
  • 1,744 posts
Posted 03 September 2019 - 08:01 PM
This has just answered my question thanks, what’s the hole for anyway ? And how much grease should be in this thing, I’m currently stripping mine down and did wonder about that plate
#12 KTS
KTS
  • 2,459 posts
Posted 04 September 2019 - 11:55 AM
at a guess, i'd say it's to drain/ventilate the inside of the shifter housing when water gets in there
another neat bit of design on the housing is the 'funnel' shape where the gear selector shaft goes in meaning there's a high probablity of water and general muck being forced in (..and any grease being washed out..) when driving in wet weather
shouldn't need huge amounts of grease - a liberal coating on all the moving parts should be sufficient.
worth considering replacing the bushes the shafts run in - especially the front one, and checking the main selector shaft for excessive wear where it runs in the bush
#13 leepol83
leepol83
  • 1,744 posts
Posted 04 September 2019 - 06:15 PM
Thank you for that, what do the bushes look like ?
#14 Spider
  • 15,129 posts
Posted 04 September 2019 - 06:57 PM
There was at one time, a boot that went on here to stop that
They are a DU Bush, not available as a spare part from Mini parts suppliers;-
However, most Bearing shops will have them.  I Have a P/N somewhere (or do a search), but the size is 0.005" ID x 0.600" OD x 0.500" L
#15 KTS
KTS
  • 2,459 posts
Posted 04 September 2019 - 09:07 PM
i got mine from this site - i'm sure other sites stock them though
https://www.onlinebe...h-Imperial.html
Part number is:  08DU08  (1/2 x 19/32 x 1/2)
i didn't fancy my chances of being able to get the old ones out and new ones in without destroying the bushes or the housing so got the local machine shop to do them for me
