Ducellier Ignition Coil
5 replies to this topic
#1 miniman86
miniman86
  • 1,939 posts
Posted 27 August 2019 - 06:59 PM
Hi everyone,
I've recently put a metro 1275 engine into one of my minis, which has a ducellier ignition coil, plus an electronic ignition (think its the 64d dizzy?) my worry is that the coil may be one of the ballast resistor type coils, and the mini I've put the engine into is a 1982, so has a 12V feed going into the coil. is there any way i can tell whether this coil only needs 9V, or whether the full 12V is fine?
Thanks in advance,
Alex
#2 mini-mad-mark
mini-mad-mark
  • 852 posts
  • Local Club: northants wot no brakes
Posted 27 August 2019 - 10:52 PM
With a multi-meter you can check the resistance of the coil  - I believe 1.5 ohms for a ballast or 9v coil and 3 ohms for a non-ballast 12v coil
If it is a ballast coil (9v) I think it will give you a nice fat spark all the time (not just for starting) but may not last long pushing 12v through it all the time.
Nice simple explanation here:
http://classicmini.w...ing-a-coil.html
#3 Benoit_Dupont
Benoit_Dupont
  • 291 posts
Posted 28 August 2019 - 05:23 AM
I actually have a similar coil on a 1275 '91 Cooper with Electronic ignition. I tried to measure it and ended up with an odd 0.8 ohm Reading... Don't know what to make of this value.
#4 whistler
whistler
  • 1,797 posts
Posted 28 August 2019 - 08:23 AM
My 1275 came with a ducellier coil and a 65dm4 electronic disributer. it worked fine. I have since replaced it but keep it as a spare for running up test engines.
#5 Ethel
  • 25,965 posts
Posted 28 August 2019 - 08:41 AM
Not sure the make matters, there are basically 3 original equipment coils:
unballasted (3 ohm), ballasted (1.5 ohm), electronic ignition (1 ohm). That's the resistance measured across the low tension connectors with all other connections removed.
Probably not the exact values but close enough to decide which coil you have.
#6 miniman86
miniman86
  • 1,939 posts
Posted 28 August 2019 - 12:43 PM
Cheers for the help. It's a 1ohm coil, so perfect for what I'm using it for. Thanks!
Alex
