Alloy Callipers
17 replies to this topic
#1 leepol83
leepol83
  • 1,744 posts
Posted 31 August 2019 - 10:29 AM
Hi I’m after a set of the minisport alloy callipers to replace my standard 8.5” setup, I’m a little confused what I will actually need to do the conversion, will The calipers just bolt strait in and retain the original metal disc covers or do I need discs and stuff ?
#2 bikewiz
bikewiz
  • 321 posts
  • Local Club: NEMO
Posted 31 August 2019 - 11:37 AM
They bolt straight on, I needed to shim the caliper around a millimeter to get it to center on the disc rotor. You remove the disc covers. For the cost you'll want new disc rotors, and when you get the calipers, you need new pads as they aren't supplied with them. Make sure you put them on the correct sides, the bleeders point up. You may want to replace the flex line while you're doing the install. You should also bleed the whole system.
#3 leepol83
leepol83
  • 1,744 posts
Posted 01 September 2019 - 03:50 PM
Brilliant thank you, the set I’ve found comes with Torox vented grooved discs, and green stuff pads, assuming these will bolt strait on with them being vented ?
#4 leepol83
leepol83
  • 1,744 posts
Posted 20 December 2019 - 07:58 PM
Hi chaps fitted these mini sport alloy calipers today, do I need longer caliper bolts ? Mine don’t seen that long is this a common thing ?
#5 GraemeC
GraemeC
  • 7,467 posts
Posted 20 December 2019 - 08:19 PM
Do you have any threads exposed that have gone right through the hub?
#6 leepol83
leepol83
  • 1,744 posts
Posted 20 December 2019 - 08:31 PM
No can’t see them on the other side I did look at that, it just didn’t seem long enough, assuming you should see the thread just poking through the disc side ?
#7 GraemeC
GraemeC
  • 7,467 posts
Posted 20 December 2019 - 08:41 PM
Yes - you need full thread engagement (but not so much excess that they touch the disc obviously).
#8 leepol83
leepol83
  • 1,744 posts
Posted 20 December 2019 - 09:23 PM
Ok that’s what I thought, where can I get some abit longer from ?
#9 GraemeC
GraemeC
  • 7,467 posts
Posted 20 December 2019 - 09:42 PM
Ask MiniSport what they recommend, and with what washers as they will obviously make a difference.
#10 Ethel
  • 26,580 posts
Posted 20 December 2019 - 11:51 PM
You'll also want bolts as opposed to setscrews.
Minispates do some 53k1049
#11 nicklouse
  • 18,998 posts
Posted 20 December 2019 - 11:55 PM
Sorry but sounds like typical. MiniSport providing poor kits.  My MiniSpares alloys calipers came with all the correct mounting kit
#12 leepol83
leepol83
  • 1,744 posts
Posted 21 December 2019 - 04:48 PM
Thanks I’ll look into this further, will probably just get longer bolts ??
#13 leepol83
leepol83
  • 1,744 posts
Posted 21 December 2019 - 06:39 PM
Just a thought can anyone who’s fitted minisport allot calipers tell me the length of the caliper bolts they used ?
Cheers that might help
#14 leepol83
leepol83
  • 1,744 posts
Posted 23 December 2019 - 11:55 AM
Just incase it helps anyone these are longer from Minispares :-
53K1049
These are 3/16” longer ??
#15 Midas Mk1
Midas Mk1
  • 5,823 posts
  • Local Club: S.U.N.M.C
Posted 23 December 2019 - 12:31 PM
Have you even seen a Minisport kit, typical? Sounds like a typical TMF response from CERTAIN members,
I've had 4 kits, all come with the needed hardware, the correct caliper bolts.
Edited by Midas Mk1, 24 December 2019 - 07:45 AM.
