Spi Rev Counter Bulb Blown
Posted 19 September 2019 - 11:43 AM
I’m sure this has been asked before so apologies in advance.
Do I need to remove the dash to replace the Rev counter bulb on a 93 SPI cooper?
Posted 19 September 2019 - 01:46 PM
If you remove the vent at the RH end of the dash you can get enough access to change the bulbs, the bulb holders need turning anti-clockwise slightly (looking from the rear) and they'll pop out easily. If your hands are too big find someone with smaller hands to help out!
The vent can be removed by unscrewing the chrome ring, then rotate the vent slightly anti-clockwise and pull it out, then the feed pipe can be removed by twisting and pulling.
Posted 19 September 2019 - 05:29 PM
Posted 19 September 2019 - 06:16 PM
Good luck !
Should and could are 2 marvellous words
Posted 19 September 2019 - 07:57 PM
I know my 1980- 1993 cars do
Edited by cal844, 19 September 2019 - 07:58 PM.
