Major Oil Leak
Posted 20 September 2019 - 12:32 PM
Mostly running down under timing cover. Could the timing cover be a suspect in a big oil leak or is it more than likely the half moon seal leaking?
On the upside the mini passed its MOT yesterday . It's first for seven years!
Posted 20 September 2019 - 12:36 PM
You say running down the timing cover which would suggest a leak above the timing cover.
Check the Rocker cover gasket first. I assume its a 1275 lump
Posted 20 September 2019 - 12:51 PM
Posted 20 September 2019 - 01:01 PM
Ah !.............So it's a General leak, not a Major leak, but so long as you don't drive anywhere, it'll remain a Private leak.
Edited by DeadSquare, 20 September 2019 - 01:03 PM.
Yes likely culprits are the half moon, but check the Crank front pulley damper seal first as that's easier to replace. If its been sitting for ages its possible its "rotted" and been chewed up
Posted 20 September 2019 - 03:32 PM
I'd say the half moon is less likely as there's nothing to disturb it. Shouldn't be too hard to work out if you pack behind the end plate with something absorbent and she if it gathers more oil from above or below.
