Mpi Bulkhead Foam Sound Deadening
13 replies to this topic
#1 leepol83
leepol83
  • 1,744 posts
Posted 22 September 2019 - 04:35 PM
Hi I’m just wondering which order to do this, I’ve got some new foam for the engine bay side if the bulkhead bit I’m unsure do I fit this before the wires, wiper motor etc or afterwards?
Thanks ?
#2 cal844
cal844
  • 9,623 posts
  • Local Club: TFMOC
Posted 22 September 2019 - 06:33 PM
Don't fit the engine bay side insulation as it will trap moisture
#3 leepol83
leepol83
  • 1,744 posts
Posted 22 September 2019 - 08:49 PM
Thanks for the advice, but if I was to fit it would you do it first or after wiring etc ?
#4 cal844
cal844
  • 9,623 posts
  • Local Club: TFMOC
Posted 22 September 2019 - 10:18 PM
The sound deadening goes in before the wiring and fuse box, personally I dont fit them as it traps moisture and can be fiddly to work around. You might be able to make a few neat cuts so the deadening pad is removable without having to remove the wiring etc.
Hope I'm helping you with this advice.
Regards
Cal
#5 leepol83
leepol83
  • 1,744 posts
Posted 23 September 2019 - 06:33 PM
Lovely thanks mate, very helpful
#6 Rorf
Rorf
  • 866 posts
Posted 23 September 2019 - 07:34 PM
I would never put sound deadening in the engine compartment of a carb mini. Stick it inside the dash against the firewall.
#7 cal844
cal844
  • 9,623 posts
  • Local Club: TFMOC
Posted 23 September 2019 - 08:49 PM
I agree and sealer the front window once the rust is fixed properly ?
#8 leepol83
leepol83
  • 1,744 posts
Posted 24 September 2019 - 06:17 AM
#9 leepol83
leepol83
  • 1,744 posts
Posted 24 September 2019 - 06:18 AM
Mines a mpi mini does that make a difference
#10 jaysmini1983
jaysmini1983
  • 217 posts
  • Local Club: West Country Mini's
Posted 24 September 2019 - 06:58 AM
again, as said above. they hold water!!! not what you want on a mini at all! just buy some sound deadening mat and fit to the inside(dehind dash) i did mine last night with 10mm stickyback close cell foam.
#11 leepol83
leepol83
  • 1,744 posts
Posted 24 September 2019 - 06:57 PM
Ok thanks I will be fitting it as I’m looking for originality and it’s how it came out the factory,but thank you for all of you’re opinions On weather to fit it or not that’s really helpful!
Thanks again
Lee
#12 MikeRotherham
MikeRotherham
  • 976 posts
Posted 25 September 2019 - 11:26 AM
There are some under bonnet foam insulation pads around that are closed cell. I think the ones Smiffys Bits sell are.
#13 leepol83
leepol83
  • 1,744 posts
Posted 25 September 2019 - 07:47 PM
Thanks mate that’s the type I’ve been looking at it’s foam
#14 leepol83
leepol83
  • 1,744 posts
Posted 10 November 2019 - 08:08 PM
Hi all back to actually fitting this now has anyone got a picture of the closed cell foam fitted to the engine bulkhead on a mpi mini just for reference ?
