7 Port Head - Webers Vs Fuel Injection
7 replies to this topic
#1 NunoTT
NunoTT
  • 64 posts
Posted 23 September 2019 - 09:26 AM
For quite some time now I've been planning on installing a 7 port head on a spare engine that I have.
I've alway had the idea of using 2 Weber 40 DCOE carbs, but after having two in my Datsun and having a bunch of throuble tunning them I'm thinking of opting for fuel injection in the Mini.
Has anyone done this? Is the extra price worth it? What fuel injection kits are out there? The only one I know is from Specialist Components...
Any opinion and suggestions are highly welcome!
Thanks in advance!
Nuno TT
#2 MiniMadRacer
MiniMadRacer
  • 894 posts
Posted 23 September 2019 - 09:36 AM
I have never used Fuel Injection on my Racer as the rules ban it. I use a Weber 48 (Single)  on a 5 port head with a long manifold.
I would guess Fuel injection would be much better, so much more "tunable", and should give more power and use less fuel, but I have no first hand experience using it on a  Mini
#3 Dusky
Dusky
  • 5,322 posts
Posted 23 September 2019 - 09:45 AM
Fuel injection really transforms a car. That being said, webers are a lot cheaper and achieve the same MAX BHP.
#4 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,091 posts
  • Name: Neil
Posted 23 September 2019 - 11:29 AM
I am going down the 7 Port head conversion route with throttle bodies.
Hopefully it will be pretty much fit and forget once the map is written for my setup. I love Weber’s having run them on my RS for many years but you do need to keep on top of them.
It’s like anything there are other factors to consider to get the most out of both systems. It’s not just a case of fitting them and they will work straight out of the box. Things like fuel delivery, ignition systems and the all important rolling road setup to optimise the output and running.
#5 mk1leg
mk1leg
  • 9,343 posts
Posted 23 September 2019 - 05:04 PM
I was very happy with my 7port set up this was a Vintage Mini 7port large  valve head came with 4 Suzuki ready set up carbs I had 115bhp with my 1380 with SW8 I did inquire about the SC fuel injection set up for the 7port head but this was an extra £2300
#6 Turbo Phil
Turbo Phil
  • 2,426 posts
Posted 23 September 2019 - 06:19 PM
Use a single throttle body and a plenum chamber. Coupled with an ECU such as Megasquirt, you could run fuel injection for a few hundred pounds.
Phil.
#7 Shooter63
Shooter63
  • 1,102 posts
Posted 23 September 2019 - 07:58 PM
Just get a set of bike throttle bodies most of which come with injector bosses, get a manifold made up by a company like Danst, low pressure pump near the tank, swirl pot, regulator and high pressure pump up the front, fuel return line to the tank, ecu of your choice, Ford gen 2 coil, crank trigger etc and you're ready to go. No more carbs flooding and faffing about, starts all the time, whats not to like.
Shooter
#8 Gilosmini
Gilosmini
    Starting My Mini Up
  • 2 posts
  • Local Club: Bumpstart Cornwall
Posted 06 February 2020 - 07:46 PM
I have the SC 7 Port with their ECU and ITBs on the billet head. Fuelling was initially pulse rather than sequential. Rebuilt it with the carb crank trigger wheel setup for sequential fuelling. Very responsive. Selling it all in the near future if interested.
