The Difference Between Pre A+ And A+ Gears
2 replies to this topic
#1 MacFreuden
MacFreuden
  • 31 posts
Posted 26 September 2019 - 05:45 PM
Hi all,
Just wondering if I could use some of my older pre-A+ gears (2nd in particular) on a A+ gearbox as the A+ one is quite chewed up and needs replacing.
Both have 26 teeth and apart from that I cant see many other differences ....
Any suggestions for yay or nay would be great thanks !
#2 Spider
  • 14,867 posts
Posted 26 September 2019 - 06:19 PM
The early A+ Gearboxes shared many of the same gears as the A types, however, the identifying feature of the A+ Gears is the line(s) that are ground across the tops of the teeth. These Gears are different and bot compatible with A types. The Helix Angle is slightly different and the Tooth Form is very different.
#3 Ethel
  • 25,938 posts
Posted 27 September 2019 - 08:56 AM
Do you know about http://www.guess-works.com/Shop/ ?
