Water Temperature Sensor
9 replies to this topic
#1 JonnyAlpha
JonnyAlpha
  • 2,748 posts
  • Local Club: Exmoor Minis
Posted 29 September 2019 - 07:39 PM
I picked up a Water Temperature Sensor from MiniMine yesterday at Castle Combe, asked for a 1275 A+ Water Temperature Switch.
When I got home and compared it to the one from the Metro Engine that I am rebuilding it looks slightly longer and the nut section is deeper?
#2 cal844
cal844
  • 9,660 posts
  • Local Club: TFMOC
Posted 29 September 2019 - 08:04 PM
That's a mini one you've bought, the metro one iirc is different, you might be able to return the new item for either a replacement or refund.
Have you tried it (gently) in the head?
Edited by cal844, 29 September 2019 - 08:05 PM.
#3 nicklouse
  • 18,724 posts
Posted 29 September 2019 - 08:46 PM
What gauge are you using?
#4 JonnyAlpha
JonnyAlpha
  • 2,748 posts
Posted 04 October 2019 - 10:43 AM
Sorry didn't see these replies (forgot to click follow). It's an A+ Engine so why is the Mini one different to a Metro one?
The water temp gauge is the standard one found in the twin instrument cluster Mk4 1982 HLE 1000.
#5 Ethel
  • 26,104 posts
Posted 04 October 2019 - 12:01 PM
It looks fine to me, they seat on the taper at the inboard end of the threads, so put those level and you'll see where it'll be shorter of longer.
https://www.autoelec...snb103-71-p.asp
#6 nicklouse
  • 18,724 posts
Posted 04 October 2019 - 02:26 PM
the Metro gauge IIRC requires a different input to the Mini one. though the fitting is the same the sender can also look different from different makers.
#7 JonnyAlpha
JonnyAlpha
  • 2,748 posts
Posted 04 October 2019 - 03:00 PM
Sorry still slightly confused, I will be fitting a Metro A+ 1275 into a 1982 998 HLE Mini, the instrument cluster is a Mini one. Do I need different senders for Oil Pressure and Water Temperature, or will the Mini ones fit and work in the Metro A+ block - surely the engine is the same?
#8 nicklouse
  • 18,724 posts
Posted 04 October 2019 - 03:17 PM
everything needs to suit the dials. the engine is no different but the senders were. forget it is from a Metro. it is just an A+ and you need to fit mini bits.
#9 Icey
Icey
  • 1,554 posts
Posted 04 October 2019 - 03:48 PM
They aren't as picky as you think. I've got a Metro A+ 1275 with the original sender, a voltage regulator on the back of a centre binnacle and a temp. gauge from a random Rover.
There aren't that many options, most manufacturers used the same parts.
#10 Dusky
Dusky
  • 5,322 posts
Posted 04 October 2019 - 06:45 PM
Compare the ohm readings at different temps and go from there.
