Running, Fizzing Liquid Noise On Engine Cut Off. Help!
8 replies to this topic
#1 Si675
Si675
    Just On Tickover
  • 5 posts
Posted 15 October 2019 - 11:20 AM
Hi All,
Have recently joined the classic mini world purchasing myself a beautiful 1988 Austin Mini. I'm dearly in love with it (although alot of work ahead).
The car has been sat for two weeks whilst i have been away. Been out for a drive today and noticed a strange noise coming from the engine on cut off. This cannot be heard when its running, Its only when i turn off the engine i get a noise, Sounds like running water/liquid going somewhere. No leaks underneath that i can see.
I took a video and uploaded to YouTube to further explain how the noise sounds (May have to turn the volume up as its quite subtle) - https://youtu.be/C6a0CB_Qdhc
Any help much appreciated.
Thanks,
Simon
#2 MiniMadRacer
MiniMadRacer
  • 892 posts
Posted 15 October 2019 - 01:53 PM
I cant listen to the Vid at work, but I suspect its water "gurgling"... does the car over heat, is the rad cap on properly, and is the rubber on the Rad cap in tact ?
#3 phillrulz
phillrulz
  • 617 posts
Posted 15 October 2019 - 02:01 PM
Hi All,
Thanks,
Simon
Hard to hear, could be coolant boiling on the engine when the water pump stops, was that video with the engine up to temp?
#4 hunterg30
hunterg30
  • 349 posts
Posted 15 October 2019 - 02:03 PM
When cold .Check your rad is topped up and run the engine with rad cap off to bleed the air out
#5 Si675
Si675
    Just On Tickover
  • 5 posts
Posted 15 October 2019 - 03:28 PM
No worries, Car holds temp nicely and doesn't overheat (According to heat dial) Only really creeps above middle on long journeys. Checked the rad cap, On properly and all intact. :(
#6 Si675
Si675
    Just On Tickover
  • 5 posts
Posted 15 October 2019 - 03:30 PM
Hi All,
Thanks,
Simon
Yeah sorry about that audio quality. It is very subtle. But still bugging me! Yeah engine was to temp, Took the video just after i got back from a drive.
#7 Si675
Si675
    Just On Tickover
  • 5 posts
Posted 15 October 2019 - 03:33 PM
Thanks mate will try this. I did a flush, Top up and bleed a month ago when i got the car but maybe not enough of a bleed.
#8 hunterg30
hunterg30
  • 349 posts
Posted 15 October 2019 - 08:07 PM
make sure heater inside car is set to circulate heat to help bleeding air
#9 Si675
Si675
    Just On Tickover
  • 5 posts
Posted 16 October 2019 - 08:28 PM
Thanks for your help, I've discovered the heater valve is corroded a little so it barely opens. Have ordered a new one, should come in the next few days! Fingers crossed that can help resolve the issue. Will keep you posted :)
