Battery Cable Routing
1 reply to this topic
#1 Abbot
Abbot
  • 105 posts
Posted 19 October 2019 - 04:13 PM
Hi my Mini project has been hibernating for a long time and I am now getting stuck back into it.
I am fitting a new battery cable and just trying to workout where it should run around the front subframe.
I have fitted it up to the exit of the long metal clip that hold the cable from back to front.
Looking at the old cable i see it has a U shape to it and then it needs to run around the subframe.
Does anyone have either a diagram or a photo of where it runs and the attachment points for the P clips
#2 Cooper Mac
Cooper Mac
  • 222 posts
Posted 20 October 2019 - 05:03 PM
Hi Abbot,
Here are some terrible photos I took yesterday, just before I removed the subframe:
C8-FED519-CDBF-445-B-A790-51485-A333422.
The cable goes the clutch side of the subframe, this first fixing (from the Starter motor, back), which is just to the left of the axle stand, is a screw and nut, which you can just see!
E63567-E3-8885-499-D-B875-90673865-D8-D2
There are 3 self tapping screws to the right of the axle stand in this photo, and then it’s onto the floor pan!
Sorry they are not too clear, but hopefully will help you?
Nic
