Camshaft Bearing Replacement
2 replies to this topic
#1 JonnyAlpha
JonnyAlpha
  • 2,748 posts
  • Local Club: Exmoor Minis
Posted 19 October 2019 - 06:31 PM
I am about to pick my A+ 1275 block up from the machinist having had the final face skimmed and I was going to start building it up.
The Camshaft Bearings have not yet been replaced but I don't have the new Cam yet and the machinist needs the cam to put the bearings in. My old cam is packaged up and I was going to send it away tomorrow.
If I don't have the Camshaft in and I fit the Crank and Pistons is this going to make it difficult to replace the Cam Bearings?
#2 nicklouse
  • 18,693 posts
Posted 19 October 2019 - 06:40 PM
You don’t need the cam to fit the bearings. You just need a tool to press them in. But I would not be fitting the crank and rods yet.
#3 Tupers
Tupers
  • 4,156 posts
Posted 19 October 2019 - 07:16 PM
The machinist probably wants the cam so they can check the bearing clearance once the new ones are pressed in.
It used to be the case that cam bearings would need reaming to size after they were pressed in although modern ones normally don’t.
Either way I wouldn’t fit any components until the cam bearings have been fitted.
Edited by Tupers, 19 October 2019 - 07:16 PM.
