What Is Wiper Control Unit?
4 replies to this topic
#1 ochumi
ochumi
  • 63 posts
Posted 15 November 2019 - 10:48 AM
hi im changing the drive column for a mpi column and now im fixing the wire and on the wiring i look the wiper control unit
 and i dont know what is it? any one can explain something like this or where i can find it?
thanks
#2 Kubbar
Kubbar
  • Just Joined
  • 82 posts
Posted 21 November 2019 - 07:43 AM
thanks
Dear
can you explain what is your issue, because i had a same issue and solved
the wiper control unit is a RED relay under the dashboard and speedo its Function Interval switches control the automatic stopping and restarting of the windscreen wipers at regular intervals
the part code is: YWC10152
also behind this relay there is two yellow relay one of them the power for the wiper
if you can explain what you need exotically
thanks
#3 Ethel
  • 26,104 posts
Posted 21 November 2019 - 01:15 PM
The wiper control unit will control the intermittent wipe. You'll need to do some additional wiring, the system will be common with MGF's and other Rover models if it helps you source parts and information.
If you're intending to fit an airbag to a car that didn't have one that could be dangerous and would be illegal in the UK, so probably also in Spain?
#4 ochumi
ochumi
  • 63 posts
Posted 17 June 2020 - 06:32 AM
Yes its the relay YWC10152, do you know where can i find It, or compatible?
Edited by ochumi, 17 June 2020 - 12:15 PM.
#5 PACINO
PACINO
  • 775 posts
Posted 25 June 2020 - 12:13 PM
Ahí parece que venden uno:
https://www.mg-rover...ww1352/641/1547
