Suggestions For Nordshleife Engine
6 replies to this topic
#1 Curley
Curley
  • 476 posts
  • Local Club: Not MINI friendly
Posted 19 November 2019 - 10:03 PM
It's long been a wish of mine to take my Mini to a track day at the Nurburgring. I've been round a few time on a tourist days in my MINI and am worried my existing 3.9 FD Mini engine is not a good match for such a long track.
If you had to build an engine with only one goal, to make it round the ring for a whole day, what spec would you build?
Few rules:
  • No engine swaps, must be an A/A+/MPI block
  • Must support crank fired timing (existing ECU)
  • Work with my existing front mount rad & electric water pump
  • Must be a dog box, ideally A+ rod style
  • Points for originality
The car will be taken to the track on a trailer so not got to worry about light switch clutches or poor idle speeds.
I've considered a KAD16v with 74mm pistons on their 4 speed dog box - not sure on FD. Like the idea of a similar spec EFI 8 port.
Genuine query, all discussion welcome.
#2 nicklouse
  • 19,067 posts
Posted 19 November 2019 - 10:06 PM
i would not.
just a standard engine would be fine.
#3 Curley
Curley
  • 476 posts
Posted 19 November 2019 - 10:23 PM
I don't follow, are you saying you would not build an A series for the nurburgring?
As you know the 'standard' 1275 came in many varieties over the years, not sure I know the version you're referring to. Do you mean a 'standard' race engine with DCOE?
#4 nicklouse
  • 19,067 posts
Posted 19 November 2019 - 11:17 PM
correct i would not build an A for the Nordshleife.
But if i was going to spec one then it would be more of a basic rally spec build with torque and then spec a higher than rally spec final drive.as in 3.1 or higher. there is no way i would want to sit at over 7k on the 12 mile straight.
i have say that it is a place that holds zero interest to me to drive in my Mini. i might pop round in in my Swift though one day as it is just up the road from me.
#5 mini13
mini13
  • 3,811 posts
Posted 20 November 2019 - 08:35 AM
are these your rules??
the 2nd one confuses me, existing ecu, whats the exisiting ecu?
#6 haz
haz
  • 568 posts
Posted 20 November 2019 - 09:05 AM
Engine swap would make a lot of sense though. More gears, more power, more reliability & MUCH cheaper.
#7 r.tec
r.tec
  • 216 posts
  • Local Club: SfG Schoenau
Posted 20 November 2019 - 11:30 AM
I did a lot of racing on the Ring in any condition and I feel the 3.9FD is just right. Not so good on the long straight back to S-F but good enough for the rest.
[attachment=203906:STT 057kl.jpg]
STT support race for the 24h 1987
Edited by r.tec, 20 November 2019 - 11:43 AM.
