Garage Heaters?
14 replies to this topic
#1 oliver122
oliver122
  • 1,007 posts
Posted 24 November 2019 - 09:28 PM
Hi guys, I haven't been on here in a good while (buying and renovating my first house has put the mini on the back burner) anyway I've knocked the old 9x16ft garage down and I'm replacing it with a 11x24ft concrete one, I was wondering if anybody had any heater recommendations for a garage of that size, I will be lining it all out and insulating it to try and keep some heat in when i do put a heater on. Hopefully I will be able get the mini back on the road then ready for summer
#2 Chris1275gt
Chris1275gt
  • 961 posts
Posted 24 November 2019 - 09:59 PM
Hi
I have a wooden garage insulated with 50mm rockwool cavity bats. When I'm out their I find a electric fan heater with a thermostat and an oscillating function is more than sufficient.
#3 MatthewsDad
MatthewsDad
  • 819 posts
Posted 24 November 2019 - 10:37 PM
You may already have considered but very worthwhile putting down a damp proof course below the concrete base and tieing it in correctly with the walls. Without a dpc the warm air will simply draw moisture into the garage from below.
#4 JXC Mini GT
JXC Mini GT
  • 851 posts
Posted 25 November 2019 - 11:50 AM
I use tubular heaters controlled by a thermostat, they will be cheap to run if the garage is well insulated.
#5 sid trunley
sid trunley
  • Validating
  • 23 posts
Posted 25 November 2019 - 05:25 PM
I would go for a fan heater and turn it off when the garage is not in use the chap did not mention turning the tubular heaters off I know they have a room stat but there still be burning juice 24 7 use a good heavy duty linen cover  should do the trick over winter SID
#6 Avtovaz
Avtovaz
  • 1,263 posts
Posted 25 November 2019 - 06:10 PM
this is what i have
click here
its silent, it work extremely well, you can use the timer for it to come on just before you go into the garage, it has an eco mode, they are the best way. Dont get a cheep one, buy once and itll be right . Our garage is about the same size as yours, and it gets far too hot in there at times!
#7 oliver122
oliver122
  • 1,007 posts
Posted 25 November 2019 - 07:37 PM
Cheers for the reply guys,I've put a dpm down and it will have 50mm kingspan in when it's built. Never really gave an oil filled rad any thought, did think of putting a couple of the tubular heaters in and wiring them into a stat but might look at the rad idea
#8 alex-95
alex-95
    I am THE CLAMP MAKER
  • 6,034 posts
Posted 25 November 2019 - 07:41 PM
I saw these www.ebay.co.uk/itm/ALL-IN-ONE-5KW-12V-Air-Diesel-Heaterddiesel heaters being used by a couple of people so ended up getting one myself for my (well parents) double garage. It seems to be very good so far, it pushes out a lot more heat that the 2 electric oil heaters.
#9 mercenary62
mercenary62
  • 359 posts
  • Local Club: mini clan
Posted 25 November 2019 - 08:19 PM
I use a calor gas super ser heater  does me fine in my 24x 13 garage
#10 danie garry
danie garry
    I love BMW minis
  • 2,296 posts
Posted 26 November 2019 - 08:42 AM
i've used fan heaters, oil filled rads, gas heaters and diesel heaters and the best really is the diesel heater(my garage was maybe 25x25 but the low roof helped), plus you don't have to worry about the surprise electricity bill next month because you left the electric heater on, nice you have a pay as you go kind of heater!
https://wholesalewel...product_id=5084
might be an ideal time to buy one with the black friday deals on
#11 oliver122
oliver122
  • 1,007 posts
Posted 26 November 2019 - 01:45 PM
i looked at them as my mate has just put one in his landrover so was considering it was just thinking of best way to exhaust it as the garage supplier recommends not drilling the panels
do you get much moisture produced from it , im sure i read that it adds moisture to the air ?
how do you go on with the fumes in an enclosed area ? or have you always go keep abit of air flow when using it ?
#12 Chris1275gt
Chris1275gt
  • 961 posts
Posted 26 November 2019 - 02:12 PM
A calor gas heater without a flue to outside air produces a gallon of water, on average per bottle, as a by product of combustion. That's a lot of warm steam to condense on anything cold and metal in a garage.
#13 mercenary62
mercenary62
  • 359 posts
Posted 26 November 2019 - 04:40 PM
a gas bottle lasts me over a year   so  not much water  from condensing per week  ,the garage is also well ventilated , and as I live in Scotland ,it gets its fair share of water driving it in our weather up here , no matter what you use ,your mini will rust to buggery over the years unless of course its garaged and hardly used
#14 Avtovaz
Avtovaz
  • 1,263 posts
Posted 14 December 2019 - 11:27 PM
the oil heaters you just get from wilkos wont do the job, get the delinghi one i linked and itll heat it np.
#15 surfblue
surfblue
  • 1,827 posts
Posted 07 March 2020 - 06:13 PM
Im just about to have my new garage erected next month :D  , galvanised steel framed and steel clad with a non drip roof membrane. Its 12m x 8m x 3.5m at the eaves.
I have resigned myself to the fact that it will be cold in winter, It would cost a lot to insulate a garage that size and heating costs would also be prohibitive. But it will be dry (DPM under the concrete slab) and will give me lots of space for lots of projects, coming from a single garage that we have at the minute where its not really big enough to do any meaningful work on the Mini I end up working on it in the driveway anyway so it will be a huge improvement over what I have now. Cant wait, been dreaming of this for years!
