Metro Turbo Caliper Spacer For Vented Discs
12 replies to this topic
#1 1293gt
1293gt
  • 322 posts
  • Local Club: nonw
Posted 15 December 2019 - 07:49 PM
Hello all,
as above, I only need one but will buy a pair if required.
Anyone got any???
Ta.
#2 Ethel
  • 25,984 posts
Posted 15 December 2019 - 11:45 PM
Didn't they lose the spacer when they all went over to vented discs in '85?
Minispares do 'em for their Alloy calipers.
#3 nicklouse
  • 18,622 posts
Posted 15 December 2019 - 11:48 PM
The vented discs had the spacers.
but it does depend on what part is actually wanted.
#4 1293gt
1293gt
  • 322 posts
  • Local Club: nonw
Posted 16 December 2019 - 08:15 AM
Part actually wanted is the spacers, 2 of them for a single caliper/
#5 Ethel
  • 25,984 posts
Posted 16 December 2019 - 11:41 AM
I am as good as certain the spacers were dropped. It would make no sense to manufacture calipers then modify the lot with extra parts once solid discs were discontinued.
I know it doesn't help you find a spacer, but it does suggest a more probable solution if you can't.
In most circumstances you could get at least as satisfactory an outcome by removing the spacers and going over to solid discs.
#6 1293gt
1293gt
  • 322 posts
  • Local Club: nonw
Posted 16 December 2019 - 01:10 PM
Thanks very much for that matey.
I've both types of caliper,
Vented type and non vented type. There was a period where BL themselves used to put spacers in there (I've still got some somewhere but can't find them).
Thanks,
#7 imack
imack
  • 2,135 posts
Posted 16 December 2019 - 01:35 PM
Same caliper halves were used for vented and solid discs on early metros, the turbo vented discs all had the spacers between the caliper halves for the extra width of the Vented disc. When the metro was face lifted in around 85 all metros got the turbo vented disc setup and they widened one half of the caliper to eliminate the need for the spacers.
Edited by imack, 16 December 2019 - 01:36 PM.
#8 Ethel
  • 25,984 posts
Posted 16 December 2019 - 02:08 PM
The early vented discs were also sided because the air channels were spiral.
#9 imack
imack
  • 2,135 posts
Posted 16 December 2019 - 09:17 PM
Quite correct, my original turbo brake convertion from minispares had the handed discs.
#10 1293gt
1293gt
  • 322 posts
  • Local Club: nonw
Posted 17 December 2019 - 09:51 AM
Anyone got a couple of spacers for a single caliper then?
#11 Ethel
  • 25,984 posts
Posted 17 December 2019 - 01:44 PM
Left or right?
I do have some, but I wouldn't be able to offer them for some while.
#12 1293gt
1293gt
  • 322 posts
  • Local Club: nonw
Posted 17 December 2019 - 03:02 PM
Hello Ethel,
if you could supply all 4 if you have them, cover all bases?
Thanks very much!
#13 Ethel
  • 25,984 posts
Posted 17 December 2019 - 04:20 PM
I couldn't put a time on when or if that'd happen, sorry.
Try some local motor factors, there might be some reconditioned ones still kicking around, or look at the online brakeparts sites, if nothing else you should get some part numbers to aid your search.
gbc2030 gbc2031
